black sh*t on rear bumper?
why would there be a build up of black "sh*t" on my rear bumper? It is right where my exhaust pipes are, and I understand that is obviously from the exhaust, but what exactly? Its like I'm running a diesel! Thanks
Accufab 70mm T/B and Plenum, PI Intake Manifold, K&N FIPK II, Steeda U/D Pulleys, ProChamber, Flowmaster Delta 40s Full Exhaust, Steeda Tri-Ax Short Shifter, 3.73 Gears
MM's Orangest
2004 Mach 1 Mustang
Have you been getting butt fucked by your car's exhaust tips? That would explain shit on the bumper.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
MSTRB8N & MDR8N
2021 Mustang V15
Quad Turbo with nawz
backed into a defecating cow?
MM 1 am boner crew Cars and mod list in garage i like veiny meat sliding between my buttcheeks |
Is there anyone over the age of 13 out there that would like to respond? I don't mind the jokes but you could at least provide some insight along with your humor...
MM's Orangest
2004 Mach 1 Mustang
Sorry man but I don't have a clue otherwise I would have said something.
Tree Fiddy Z
Maybe you're running rich?
MM's Orangest
2004 Mach 1 Mustang
That's the only thing I can think of, but that doesn't help him a whole lot. Have you thrown any codes or done any new mods to your car recently.
48.47@ 12.58
post a pic if you can please.
Tree Fiddy Z
when was the last time you did a tune up? Might not be burning all the fuel...those are the only 2 things i can think of at the moment.
I was thinking Im runnin rich too. I've been having some issues with my idle so I was going to replace my plugs and wires and clean my TB and plenum. I really noticed after I got the prochamber and flowmasters installed. I didn't think Id need a custom tune tho with mods I have but maybe I do. Thanks for the help. Ill post a picture later tonight too. Thanks again!
MM's Orangest
2004 Mach 1 Mustang
You probably will need a tune. I only had a RAI and exhaust and I was running lean.
2000 gt
yup unless you have cats on that prochamber you need a tune. it messes up the 02 readings. You'll have to get a tune, it's most likely just rich as hell. have a friend watch you stomp on it and see if she blows black smoke.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tqHARDCORE CREW BRIGHT ATLANTIC BLUE CREW #1 MEMBER |
No cats with the prochamber. guess that's the reason then. looks like im going to have to put out the 500 it costs to get a damn tune! that sucks! think if I get a diablosport tuner I could adjust it myself? would def be cheaper!
MM's Orangest
2004 Mach 1 Mustang
Yeah unless you screw up the tune then it could be a lot more expensive. I'd say spend the extra green and get it done right.
1989 Mustang GT
14.01 @ 103..... :(
spend the extra cash. Not much more plus its a hell of a better tune prolly dyno alittle higher numbers with a custom tune too.
![]() vortech s-trim off road h pipe super 40's steeda tri-ax c.a.i. 3.73s subframe cnntrs 255er |
~C~, The Other White Meat!
All you need to buy is the tuner. You havent changed much so you can pick up an xcal or a diablo and turn the o2 sensors off. Should run fine. However, a custom tune and dyno would yield some more power, but in an effort to save the greenback, that is all you really need to do.
And i just wanted to add that post number 4 was pure
BLOWN Bumblebeast! 370 rwhp / 381 ft lbs ![]() ~Tuned by JJ at WMS ![]() "Like the blind man says......We shall see...."
Threads Similar to: black sh*t on rear bumper?
| Do black Mach 1s have the flat black rear wing? | 03_StangGuy | 4V / SVT | 29 | July 1st, 2008 06:02 PM |
