2001 Saleen 281 #0101
Stock 3:27 vs 3:55 gears swap. Worth it?
Will I see a huge difference if I go from 3:27 to 3:55 gears? I dont want to go any steeper than 3:55 since I drive on the highway alot.
2003 gt
5.4 32v on the way
I have 3.73s and do a lot of highway driving. I don't think mpg changed too much. Go for 3.55 only if you get it so damn cheap you have to.
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
1989 Mustang GT
14.01 @ 103..... :(
3.73s arent bad on the highway.
![]() vortech s-trim off road h pipe super 40's steeda tri-ax c.a.i. 3.73s subframe cnntrs 255er |
get the 373
![]() 2000 kenne bell GT (440HP-432TQ) Tuned by Joe at http://www.tricktuners.com dyno vid:http://youtu.be/lr3xpxw2_v8 2011 escape MUSTANG TAT CREW |
Go for 3.73's.
I run 4.10's on the highway all the time. 500 miles a week. 3.73's will not be a problem. Unless you consider a perennial smile on your face a problem. |
2003 GT
3.55 won't make much difference. Go with 3.73, still good on freeway
2003 FORD MUSTANG GT
Soon
Definitely 3.73s
Priest of the Car Gods
Here's a really lame chart for you. Basically, this is what rpm you would have to turn with the respective gears to go the same speed as you would turning 2000 rpm with 3.27s
3.27 -- 2000 rpm 3.55 -- 2171 rpm 3.73 -- 2281 rpm 4.10 -- 2507 rpm
12.73@111.36
I agree that if you are going to spend the money go with 3.73s. But, this is not exactly an irreversible decision. You can tame down 3.73s with taller tires. For example, if you are currently running a 17' wheel with a tire that has a 110mm wall (245/45, 275/40, or 315/35) then you can go to perhaps a 255/50. This taller tire will make the 3.73s behave as if they were 3.55s. If you want 18" wheels then a 245/45-18 is the same diameter as the 255/50-17. Just bigger wheel and shorter tire.
The new cars coming out have advertised lower gear ratios then our. But, they are also running 20" wheels.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
^^great info!
You'll barely be able to tell the difference, 3.73's are pretty do-able and easy going.
just do 3.73's you wont be that bad off with highway driving
yup if your going to spend the $$ just go for the 3.73's you'll kick yourself later on if you don't.
4Cams,4Valves,4.10's Hell yeah
when i had my 01 GT i done 3:73 and wished i'd went with 4:10 i know what much
Cervini's type iv hood, C-series bumper, Pypes mid-muffler exhaust, WMS CAI, 20" chrome wheels, Roush rear spoiler
12.73@111.36
I now have had my 3.73s in long enough to get a good idea of the gas mileage. 3.73s will most likely reduce your gas mileage by 2 mpg. If you drive 20,000 miles per year and if gas is $3.00 per gallon then additional cost of 3.73 gears is about $273 per year. That's $5.25 per week.
#18 | |
between the 3.55 and stock, you dont gonna feel a really big difference....so go for the 3.73 |
will how about your future plans is there a blower down the road??my bud has 3.73's on his GT and drives it about 200 miles to the track with good mpg.I guess it depends how you drive it.
2003 Mach 1
Don't waste your money on a 3.27 to 3.55 swap.
Go 3.73 or 4.10's and you'll love them. My Mach 1 had 3.55's stock and I swapped to 4.10's and I love them. (I drive about 90% Highway FWIW.) |
Threads Similar to: Stock 3:27 vs 3:55 gears swap. Worth it?
| Anyone know what the stock GT mufflers are worth? | 06Black5spdGT | 2005 - 2010 | 9 | September 5th, 2008 11:02 PM |
| i have 3.27 gears, even worth the money to go to 3.73s? | 93hatch | 5.0 Mustangs | 8 | April 7th, 2008 10:53 PM |
| Swap worth it? | motorhead6776 | V6 Mustangs | 13 | January 5th, 2008 01:04 AM |
| Cam swap worth it? | hitorx | 5.0 Mustangs | 1 | March 14th, 2007 03:12 PM |
