Shifter arms?
Old March 6th, 2009, 12:24 AM   #1
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Shifter arms?
Does anyone know if anyone sells different shifter arms that will bolt to a steeda tri-ax shifter?
One of my biggest problems is that the ergonomics of the Mustang are just *wrong*. If I have my body the right distance from the pedals, I can't reach the shifter, and if I position myself to reach the shifter, my legs are all crammed up too close to the pedals. I usually split the difference, and just live with lifting my shoulders to hit 5th.
If I could find a different shift lever for the triax, then I could effectively move the shifter back a few inches, and get everything perfect.
O o
/¯/______________________
\_\
Old March 6th, 2009, 09:12 AM   #2
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
I had this EXACT issue with the chopped Hurst lever I was running:
That is the stock Ford lever and the severely chopped Hurst one I was running up untill a month or so ago. I have cut down and sewed up the shiter boot, as it was all bunched up under the Hurst one because it is soo short.
This solved my reach problem, but added travel to my shifting . I had 1.75" prior and now have probably 5.5" or so. Was worth it though to have easy reach and not twist/lean over to drive my ride.
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old March 6th, 2009, 10:26 AM   #3
'97 GT
tommyt411 is on a distinguished road
I know that this doesn't follow your question REV, but I got the MGW w/ the orange handle and I no longer have to reach up at all!!! The 360 degrees of rotation of the handle made it nice!!! Good Luck! Too bad the triax has a bolt on handle instead of the post to slide the orange handle over it...
Threads Similar to: Shifter arms?
Hurst shifter rattle on new shifter Odin 2005 - 2010 8 January 11th, 2009 12:18 AM
QA1 Tubular Control Arms (A-Arms) keith0s 5.0 Mustangs 3 October 19th, 2007 11:20 AM
steel control arms vs aluminum control arms Saleenwolf720 99-04 1 October 15th, 2007 01:32 PM
Upper Control Arms & Lower Control Arms LUV2XLR8 2005 - 2010 6 October 6th, 2007 11:45 AM
Steeda lower control arms (Trailing arms)? kmjsmith 2005 - 2010 6 July 4th, 2007 04:59 PM
