Adjusting lower control arms
Old March 14th, 2009, 09:51 PM   #1
Slider1385 is on a distinguished road
I bought a set of adjustable lower control arms. I set them for the length of the stock ones but I would like to check and make sure that my rear end is perfectly square. Does anyone know how to go about this, I did a search and came up with no good results. Thanks
Old March 15th, 2009, 11:08 AM   #2
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
You probably wont find the exact measurment, as bushing wear and amount of drop will come into play.
You will not be off by much and I would probably just do this by sight (you could measure wheel well gap too). I you were REALLY into pinion angle and such, you should go with adjustable UCA's as well.
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old March 15th, 2009, 09:31 PM   #3
I have the adjustable uppers, I know how to do those as I have an angle finder. The lowers however were the ones I'm not too sure how to measure. I just want to make sure that my rear is perfectly squared up.
Old March 19th, 2009, 02:41 PM   #4
ModMustang97GT's Avatar
1997 Mustang GT
Faster than an s4
ModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura about
simplest method would be to make sure the length is equal on both arms. But that will only give you relatively straight set up. The best way is to use a plumb bob to hang from the chassis and the end of the LCA to make sure its the same on both sides.
Aztec Gold 97GT.
MM CC Plates, Panhard Bar, SFC's & Tower Brace
Eibach Sway Bars
H&R Race Springs/Bilstein Shocks
MAC CAI, LT's, Catted H and Pro-Dumps
KB Boost-a-Spark
04' PI Motor
Author of The Official Suspension Guide
Threads Similar to: Adjusting lower control arms
Lower Control Arms UnixHH 99-04 7 December 8th, 2008 10:26 AM
lower control arms theodoor24 Classic Mustangs 2 March 9th, 2008 12:04 PM
Upper Control Arms & Lower Control Arms LUV2XLR8 2005 - 2010 6 October 6th, 2007 11:45 AM
Steeda lower control arms (Trailing arms)? kmjsmith 2005 - 2010 6 July 4th, 2007 04:59 PM
lower control arms reeds98gt General Tech 6 November 19th, 2006 11:27 AM
