Brake bleeding help!!
Old March 15th, 2009, 04:43 PM   #1
It's in the details Mod!
M.P. Cobra Fan's Avatar
01 Cobra Vert
Nov 09/10 ROTM!
M.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond repute
I need a little help. I changed out pads and rotors today on my car. Drained the system to change over to a synthetic brake fluid. Flush out the system and now have everything back together. I have just spent the last hour bleeding brakes with no luck. I still have no pedal. Flui is shooting from the rear speed bleeders approx 9 inches. The front are just dribbling out. When I remove the front lines from the calipers and pump the brakes it comes out pretty heavy. I have tried both the standard bleeders and the speed bleeders. I still have NO pedal.
Any ideas?
Pinup in signature by loish.net
Modded Mustangs Cobra Club#007
Military Crew E5
VOTED MM's BEST SIGNATURE 2010. THANKS STANGGTR07
Old March 15th, 2009, 04:47 PM   #2
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
Bleed the master.... there are two plugs on the side of it.
TT Build in progress.......
Old March 15th, 2009, 04:56 PM   #3
01 Cobra Vert
Nov 09/10 ROTM!
Thank you. I will try that.
Military Crew E5
Old March 15th, 2009, 05:54 PM   #4
01 Cobra Vert
Nov 09/10 ROTM!
That worked man. I can not beleive I forgot about that. I was getting frustrated and not thinking. I owe you a beer!
Military Crew E5
Old March 15th, 2009, 05:54 PM   #5
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Did I understand correct that you're trying to bleed all four brakes at once?
O o
/¯/______________________
\_\
Old March 15th, 2009, 05:55 PM   #6
01 Cobra Vert
Nov 09/10 ROTM!
No! I did not try that I was doing it the proper way in the proper sequence, I just forgot about that master cylinder.
Military Crew E5
Old March 15th, 2009, 06:01 PM   #7
Oh, okay, hahahahaha.
O o
\_\
Old March 15th, 2009, 08:21 PM   #8
SDYC00GT is on a distinguished road
what's the proper way to do this? I've only bled a caliper after replacing, and that was just a tad bit to clear the air....but my car has 75k miles on it so i probably should flush it.
Zinc Yellow New Edge
Couple Mods...
Looking for Boost...
Originally Posted by 99mustanggtman View Post
Just buy a used blower. Bolt ons are a waste
Old March 15th, 2009, 08:38 PM   #9
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
Bleed the master then the Pass rear, drivers rear, pass front then the drivers front.
Old March 15th, 2009, 08:48 PM   #10
Another way of saying this is after you bleed the master cylinder, you go from the longest line to the shortest.
Though I've always thought you had to bleed the t-junction at the rear axle after you bleed both the rears.
O o
\_\
Old March 15th, 2009, 09:20 PM   #11
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
It doesn't really matter there is few different ways to do it.
Threads Similar to: Brake bleeding help!!
DIY Brake Bleeding Tool (hand pump)--Think it will work? PacificMustang01 V6 Mustangs 21 July 31st, 2009 01:16 PM
Brake Bleeding Woes SITU8ED 99-04 15 February 22nd, 2009 05:50 PM
Bleeding... Mickey The Clubhouse 24 September 22nd, 2008 05:35 PM
ABS brake bleeding micldon 99-04 10 August 10th, 2008 01:29 PM
General question on brake system issues (bleeding/no pedal) 95plainjane General Tech 3 July 3rd, 2006 11:22 PM
