FRPP 3.73 gears with Motive Complete Installation Kit?
Old January 15th, 2007, 04:54 PM   #1
Blue98GT is on a distinguished road
I was just wondering if I could use Motive's Complete Installation Kit (includes bearings) with my FRPP 3.73 gears. Has anyone had any problems with Motives Installations Kits. Any suggestions for a better install kit? The kit is only $75 from http://www.americanmuscle.com/rearendrebuild.html
Old January 16th, 2007, 03:34 PM   #2
markush is on a distinguished road
I was going to ask this exact same question....interested in the answer.
Old January 17th, 2007, 12:01 AM   #3
Barrier is on a distinguished road
Well... The shims are not the problem in this situation being they themselves won't all be used (if any) and are just a tool to adjust the depth the pinion sits at in the diff. (think of them like washers used to raise bolt heads higher). Crush sleeve and the gasket (if it comes with the gasket) won't be an issue. The pinion bearing, however, will be the slightest bit bigger than stock, and that will screw you. I bought a bearing from dealer for OE measurement and we had to grind the inside quite a bit to get it to begin to fit around the pinion, then had to shop press it on. You have to use a shop press anyways, but we had to grind it before we would even think about using one.
My advice: Buy the necessary bearings, the crush sleeve (or 2 in case you screw up one), the seals, and whatever other wearing parts you see from the dealer, and re-use the shims on your old pinion. The old pinion is cut the same way as the FRPP gears, and thus using the same shims will have you arrive at the same depth as before All these parts will also cost a good amount less than $75.
But that's just my $.02
99 Dark Green Satin Mustang GT conv
K&N CAI; MAC O/R H-Pipe; Flowmaster 40s; FRPP 13lb flywheel; Motive 3.90s; Diablosport tuner; Eibach Prokit springs; Tokico Dspec shocks/struts
13.805 @ 100.23, 1.97 60'
Threads Similar to: FRPP 3.73 gears with Motive Complete Installation Kit?
Motive VS. FRPP sstang 99-04 10 October 25th, 2007 03:38 AM
motive gears? Black Five 0h 5.0 Mustangs 4 September 30th, 2007 09:32 PM
How can you tell the differents from Motive an FRPP gears. Kennhyy3 V6 Mustangs 4 April 27th, 2007 05:07 PM
Motive Gears Vs. FRPP themav46 V6 Mustangs 6 January 9th, 2007 10:58 AM
