LinkBack (2) | Thread Tools |
#1
No spark, just changed crank sensor
I am in the middle of an engine swap. i took the 2v out of my '98 gt and swapped in a 4v from a lincoln mark VIII. im using the lincoln harness, brain, and key cylinder.
Im trying to start it but im not getting any spark out of the coil packs. I got juice going into them, but no spark. I changed the coil packs, and the crank sensor but still no spark. the brain was working when the engine was pulled, so i doubt that its the problem. also i have a male 3 prong connector with some heavy gauge wire going into it. its comming right off of the negative terminal of the battery. I cant figure out what that is supposed to go into. any help would be greatly appreciated.
2011 ram 1500 hemi
you should repost this in the four valve section they should be able to help you. this section dosen't get as much traffic.
vmp500 hp. jba lts. powerhouse d/s Sold
Moderator
2012 300a gt auto
12.10@116
what year is the lincoln stuff vs. your car?
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2012 300a GT auto
LinkBack to this Thread: http://www.moddedmustangs.com/forums/modular-mustangs/116984-no-spark-just-changed-crank-sensor.html
| Thread no spark, changed crank sensor today | MIGWeb | BoardReader | This thread | Refback | December 14th, 2010 01:38 AM | |
| Thread changed crank sensor now it wont start | Kia Forum | BoardReader | This thread | Refback | September 16th, 2010 07:11 AM | |
Threads Similar to: No spark, just changed crank sensor
| Another stumbling mustang changed IAC and Tp Sensor | onerealfastang | 99-04 | 12 | August 6th, 2009 06:02 AM |
| Crank and Cam sensor | texasd18e | 99-04 | 1 | September 29th, 2008 10:51 PM |
| changed spark plugs problem | jrock | 99-04 | 8 | August 2nd, 2008 11:41 AM |
| changed my spark plugs | BWAL | 5.0 Mustangs | 24 | December 16th, 2007 09:10 PM |
| Changed spark plugs, and found some problems. | Cricket | V6 Mustangs | 20 | July 26th, 2006 11:30 PM |
