LinkBack (2) | Thread Tools |
#1
1997 Mustang GT
14.92 before current round of mods....
Worth it? You tell me...
Hi there guys. Just started posting on this site yesterday, but I have been reading for a few weeks as I tried to decide which parts to buy for some recent mods. Now I have a dillemma as to whether I should keep going or to put her back together with what I have.
What started this latest mod session was finding a nice score on some PI heads on craigslist with intake, plus aftermarket fuel rails, ported (poorly) upper plenum, timing adjuster, and I ended up getting the whole shortblock too. So I decided to add some cams at the same time. I ordered up and received the Comp 270's and beehive springs (which I will degree), and some FRPP U/D pullies. I also got the FRPP head install kit. Now I'm to the point that I "could" put the engine back together with what I have, or I could go a little further and do a few more mods before buttoning her back up. So here is what I am thinking. I can get a 3 angle valve job done from a machine shop that does a lot of work for my company for $150. I could get a 5 angle for $235. I could port the heads myself (done a few sb heads before) using the Sean Heyland book as a guide before the head job. Then I was planning on adding LT headers (BBK) and matching (BBK) o/r X-Pipe. My main question is: If I add the 3 angle valve job (or 5) and the headers, will I see a SIGNIFICANT improvement over just the manifolds and non ported/3 angled heads? I have seem anywhere from 5-15% before from the valve jobs on small blocks, and anywhere from nothing to 45HP from headers, but I have little experience with modulars. If this were your build would you spring for the extra $900 or so to gain th XX amount of HP, or is it not worth it? I do plan to have either combination tuned (probably by me with a Tweecer) and in the future I do plan on adding turbos or a KB blower. When I finish my bottom end build (maybe a year or two off). What kinda HP #'s difference are we talkin between the two combos? Thanks for help from the "hive mind".
The Hammer
Millenium Falcon
unfortunetly these motors don't really make big numbers without forced induction. the rwhp difference between the 2 setups is going to be negligible..... 10-15 at best
1998 GT Mustang
N/A
281ci is kind of pathetic when you think about it. The displacement isn't there to make big numbers NA. It could be done but to much time and money for most people.
#4 | |
1997 Mustang GT
Time for some chassis mods too methinks....
you wont see to much more HP until you go FI to take advantage the porting and valve job. but gains willbe there. 10-15hp would ba a safe guess i think. butcould be more or less.
1997 Mustang GT
So, I went and did it. I was back and forth about what to do, and decided to jump in with both feet. I am going to have the three angle valve job done, and have already begun the porting/polishing. Then I went and found an awesome deal on a set of almost new <2000mi 17x8 and 17x10.5 CHROME Bullitt's. I then ordered through work, a set of BBK ceramic headers and x-pipe, a set of FRPP header locking bolts, Steeda u/d pulleys (my supplier says that FRPP is no longer making these for this car), a BBK 78mm throttle valve/plenum, and a set of FRPP 4.10 gears and install kit. I also ordered a set of Eibach springs off ebay for a good price. And I got a great deal on a BBK CAI.
All of this is now going to go on in the next few weeks as I put her back together, and from reading this site, I have forgone my plan of building the 4.6 shortblock, and will instead find a 5.4 and build it. ![]() What do you think this combo will pull? I still need to get a tuner.... I was thinking Tweecer, but should I get a handheld, or go the custom tune route instead? ![]()
1998 GT Mustang
N/A
4.10 in a 5.4L?!?!? say hello to traction problems
1997 Mustang GT
2002 GT
99.99@999.9
i have heard that the mod motor heads can be tricky to port if you haven't had much experience. i even read somewhere that unless you have a CNC machine to not even try it. there are guys on here that have done it though. i think sweet is one of them. not saying you cant do it, but iv heard horror story's from guys that have been porting heads on older motors for years
#10 | |
1997 Mustang GT
Hope I don't screw them up too bad.
97 Mustang GT
slower than the speed of smell
yea.....you dont want 4.10s if your going with 5.4 even 3.73 is going to be a challenge from what i udnerstand. if you keep those 4.10s stay 4.6 and just get pi heads/intake and you will be happy.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/modular-mustangs/117957-worth-you-tell-me.html
| Distinct Musings of a Engineer Grad » Blog Archive » Quick scan of the net - timing adjuster | This thread | Pingback | April 7th, 2009 05:59 PM | |
| Distinct Musings of a Engineer Grad » Blog Archive » Quick scan of the net - timing adjuster | This thread | Pingback | April 6th, 2009 07:57 AM | |
Threads Similar to: Worth it? You tell me...
| What she worth | Megawatts88 | The Clubhouse | 60 | March 29th, 2009 10:39 PM |
| is it worth it? | Squints | 5.0 Mustangs | 18 | March 3rd, 2008 05:05 PM |
| what do you think its worth | dadslx | 5.0 Mustangs | 34 | January 27th, 2008 04:01 PM |
| Is it worth it? | KIKa55GT | 96-98 | 9 | January 21st, 2008 08:18 PM |
| Think it is worth it? | bheet | 2005 - 2010 | 1 | January 13th, 2008 10:37 PM |
