Discussing Manual Brake Conversion? in the Modular Mustangs Forum. Originally Posted by 1TITAN thats another concern of mine like bitmark said would there be ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 | |
I did remove my abs but kept the ps. The abs unit weighed 9lbs. -Mark
![]() -Mark- 98' N/A Cobra (Stock longblock) 11.79 at 114.64 (1.62 60ft) |
#22 |
another dahm ford
ur wrong. you can have a hose made to loop instead of steering pump to booster then to rack. have it go strait to your rack. then ur return to your reserve and back to original cycle. hydro boost work basically opposite of vacumme. it pushes instead of sucks. when i swapped my 3.8 to 4.6 i didnt have the hydro boost system and just looped the line back to rack. it was a pain in the a-hole. and i drive two days with the ebrake. but you can bypass it. look up how it works and you will see how u can do it
![]() 97' 3.8 to 4.6 swap all stock 67' mustang gt coupe 88' ranger, just a clean ass truck 48' jeep cj2 the work hogg |
#23 | |
Devil's Advocate
'98 Cobra/'90 GT 'vert
If so, that doesn't retain power steering, that just retains the power rack. It's a drifter trick (that probably came from another source) to do a cheap manual steering conversion without having to get a manual rack.
War is Peace || Freedom is Slavery || Ignorance is Strength Founder of the DMC |
#24 |
no he is saying loop the line that go to the mc. it will work and you will still have ps. you will be bypassing the mc.
1969 Early Bronco 3.5" lift 37" swampers 1969 Early Bronco 2" lift half cab 1979 2.3t Cobra 1997 Black Cobra http://www.cardomain.com/ride/680999 http://www.myspace.com/beheivjer |
#25 | |
This has been asked ever since the hydroboost came in the SN95's.
Threads Similar to: Manual Brake Conversion?
| Auto/Manual Conversion | batlaxe | 5.0 Mustangs | 23 | February 16th, 2009 11:46 AM |
| Manual Tranny To Auto Conversion | dreamr | General Tech | 6 | January 24th, 2008 06:01 PM |
| Automatic To Manual Conversion | man_of_war2081 | 99-04 | 6 | November 17th, 2007 03:59 PM |
| Auto to manual conversion | cooper323 | V6 Mustangs | 14 | November 8th, 2007 07:13 PM |
| Auto to Manual Conversion | sikdogs | V6 Mustangs | 6 | April 17th, 2007 11:00 AM |
