1997 Mustang GT
Faster than an s4
Manual Brake Conversion?
Anyone know anything about this manual brake conversion. I would love to get rid of the stock system and have an all manual set up. Steering and brakes. However, I want to make sure the manual conversion is strong enough for some bigger brakes.
http://www.latemodelrestoration.com/...0%201&comp=LRS
Aztec Gold 97GT. MM CC Plates, Panhard Bar, SFC's & Tower Brace Eibach Sway Bars H&R Race Springs/Bilstein Shocks MAC CAI, LT's, Catted H and Pro-Dumps KB Boost-a-Spark 04' PI Motor Author of The Official Suspension Guide |
Rollin' 18/ pushin' 2
Why manual brakes?
1997 Mustang GT
Faster than an s4
Lighter, and doesn't depend on engine power to work.
1998 GT Mustang
N/A
I would like to have this because i have had nothing but problems from the factory setup.
Proud American
Im converting mine as we speak... but thats because mine is a drag car...
1997 Mustang GT
Faster than an s4
Yeah, that is what I'm wondering. If its designed for drag car, it may not be suited for road racing. The pedal effort might be higher than what would be ideal.
2000 GT
12.82@104
So did you ever do the swap? Details man details.
01 mustang gt
13.98@100
i had thought about it to... my fear was everyday driving though, the anti lock has saved my ass a couple of times on the street.... if you hit the brake to hard on the track its oh well half the time and try again....
if you fuck up and panic with a break setup like that on the street its gonna be a skid brake locking tire sliding fucking disaster ![]() .... thats just my train of thought (i could also try driving like a normal person to i guess)
destroy in the turns, then obliterate on the straightaway 01 GT 4.6/20 over cold air intake/70 mm throttle body mac longtube headers/custome H pipe/moroso spiral mufflers to side exhaust computer tune race seats / 5 point harness
2000 GT
12.82@104
Im upgrading my whole brake system to an Aerospace kit this winter. Its going to be a manual system. Every pound counts in my situtation, Ill be adding weight back with Blower, Intake and cage.
how much harder r manual brakes to stop with cuz im considering doing them by myself i will be doin mostly ttrack time notmuch street driving
01 Mustang GT LS1 Swapped Victor Jr. intake Holley 750 6010 MSD ZO6 cam All Granatelli suspension TRack times to come SOOON! |
Proud American
Never driven my car yet with the manual brakes (tomorrow, I will be moving the car for the first time, into the trailer to go to the track)
But I will let you guys know...
#12 | |
Priest of the Car Gods
I understand that ABS is argued both ways (I prefer it myself, but understand the logic behind those that don't), but to get rid of the brake booster is asking for trouble. Find a car with a vacuum brake booster, disconnect it, and drive around for a bit. You definitely lose a LOT of braking power. For what it's worth, I am a proponent of manual steering.
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks Last edited by ReverendDexter; June 17th, 2009 at 01:34 AM. |
1998 GT Mustang
N/A
Thought about doing this. My stock brakes are all messed up. They only work with the master cylinder bolts loosened.
![]() Pi Swapped, K&N CAI, Diablo Tune, BBk O/R X-Pipe with Flow's dumped and a 5.4L on its way. |
2010 Mustang GT
13ish
i have drilled and slotted rotors, totally went to stop today and the ground was slightly wet from a night drizzle and my pedal came back up towards me....why?
2010 GT Black (as if there's any other color) 340hp 320tq Black Mustang Club Member #2.0
2010 Mustang GT
13ish
oh yea did i mention it was an intersection and i pooped a lil bit
IIRC your brakes work off of hydroboost so if you go to manual you also lose your power steering as well.
![]() -Mark- 98' N/A Cobra (Stock longblock) 11.79 at 114.64 (1.62 60ft) |
01 mustang gt
13.98@100
that just kinda sounds like your anti lock was kickin in... well no not really, i had a slight problem like that when my power steering pump went bad ( i got air in the lines and burnt it up)
Proud American
Brakes woreked last night... but fastest I got the car up to was 47 MPH... no good on the track passes... so we will find out Sunday if they really work.. I blew up a tranny, so now its time to get a new one in.
1997 Mustang GT
Faster than an s4
The main reason I was concerned with the power brakes is the weight and the abs. I know the abs is good, and actually can help on the track if you are lazy and don't want to brake correctly. The weight savings are pretty small really. I also liked the idea of getting rid of the lines and everything. I would love to get the car to a nice simple under the hood look. None of that extra hoses and shit that connect to god knows what.
I like the 10 wires look. 2 battery, 8 plug wires, 1 ground 1 coil plug I should create a blue tooth wireless ecu system, that would be awesome.
01 mustang gt
13.98@100
thats another concern of mine like bitmark said would there be some kind of way to retain your power steering?... in my opinion im not a fan of hydroboost brakes anyways i kinda wish that ford would of just done vacuum brakes instead
Threads Similar to: Manual Brake Conversion?
| Auto/Manual Conversion | batlaxe | 5.0 Mustangs | 23 | February 16th, 2009 11:46 AM |
| Manual Tranny To Auto Conversion | dreamr | General Tech | 6 | January 24th, 2008 06:01 PM |
| Automatic To Manual Conversion | man_of_war2081 | 99-04 | 6 | November 17th, 2007 03:59 PM |
| Auto to manual conversion | cooper323 | V6 Mustangs | 14 | November 8th, 2007 07:13 PM |
| Auto to Manual Conversion | sikdogs | V6 Mustangs | 6 | April 17th, 2007 11:00 AM |
