1997 Mustang GT
Faster than an s4
Pulling Engine Need Advice
Hey guys. I am planning on pulling the motor from the stang this weekend. I have an engine lift and a couple friends. What advice do I need. I will be following the instructions in my chilton's manual for the majority of it. But I want to know if there are any trick or anything that I should know. I am going to strip down to the short block shortly after I remove the engine, and have a machine shop survey the damage. I'm so excited, but I want to make sure there isn't anything big I need to know first.
Aztec Gold 97GT. MM CC Plates, Panhard Bar, SFC's & Tower Brace Eibach Sway Bars H&R Race Springs/Bilstein Shocks MAC CAI, LT's, Catted H and Pro-Dumps KB Boost-a-Spark 04' PI Motor Author of The Official Suspension Guide |
2001 Cobra
14.2@102 (I suck)
Make sure you have PLENTY of garage space lol. and bring in like a table or two for parts.
I like to use those dixie paper cups for the bolts and stuff, and label them witha sharpie. if youve done an engine befoe you prob know this though... Good Luck!
![]() 2001 Cobra with SRA swap, modded for twisties ![]() MM Cobra Club Member #76 |
Moderator
make sure that you have plenty of PB blaster or maybe and propaine torch so that you can heat up bolts that are stuck. also if you dont have access to a lift the easiest way is to go ahead and pull the motor and tranny together through the top if your tranny is anything like mine. If you can unbolt it from the block then do it that way.
![]() ![]() BUILD 2 IN PROGRESS Last edited by wraitherx; April 25th, 2009 at 11:47 AM. |
Threads Similar to: Pulling Engine Need Advice
| Pulling the motor, need some advice. | 03_StangGuy | 99-04 | 34 | December 24th, 2008 04:11 AM |
| Pulling an engine | man_of_war2081 | 99-04 | 16 | June 15th, 2008 06:57 PM |
| Pulling The Engine | JStang14 | 99-04 | 5 | April 10th, 2008 11:25 PM |
| Need Tips on pulling my engine | STREET6 | V6 Mustangs | 12 | February 1st, 2008 12:14 PM |
| pulling engine need advice. | hawaiiankine | 5.0 Mustangs | 10 | March 5th, 2007 12:34 AM |
