Troubles Starting? HELP
So ever since I bought my Mustang last year 1998 GT I have had starting troubles. My starter is fine because it will turn over until the cows come home, BUT my engine just doesn't fire I can count to 4 mississippi while turning it over and then it barely goes. Also I can let it turn over for a few seconds, stop and then try again and it will start right up. Seems like its not getting gas in the rails right off or something. I've tryed starting it with my foot on the gas slightly that didn't help. I tryed starting it with my foot to the floor, that didn't help. I tryed pumping the gas before starting it, that didnt help. It seems to start the same way despite what I do haha its always on the second try of turning it over or about 4-5 seconds in letting it turn over. I have a performance chip which I heard makes a difference but don't know thanks for the help fellas! p.s new sparks, fuel filter, battery, everything been the same ever since I bought the car before and after mods.
" There are alot of things to think about, but nothing to worry about " ![]()
Better? lol
#4 | |
48.47@ 12.58
Moderator
are you getting fuel at all? what have you checked, if anything?
![]() ![]() BUILD 2 IN PROGRESS |
Um to be honest Idk what to check I did the sparks, the battery the fuel filter and all that in hopes of some improvments but no luck. just need some suggestions on what to check.
2001 Cobra
14.2@102 (I suck)
before starting, turn the key to full on position(lights n dash will light up). wait like 5 full seconds and try starting it. I think that gets the fuel pump a little head start i believe
![]() 2001 Cobra with SRA swap, modded for twisties ![]() MM Cobra Club Member #76 |
Bearer of Bad News
I has mustang and legacy.
Slower than my Ruger.
Then you might want to take it to someone who does know what to check. It's always good to get multiple opinions. It could be any number of issues.
~MOD NUTSWINGER~ My Tongue Soothes Razorburn ![]() STOPSAYINGFAIL.COM EVERY FART IS A GAMBLE Just Think Of Me As A White Blood Cell.
~C~, The Other White Meat!
Yes if you turn the key to on but dont crank it, it will prime the pump which will send fuel to the rails. Try replacing the fuel filter to, it can't hurt. Perhaps you may need some new plugs.
And yes that was much better! Thanks!
BLOWN Bumblebeast! 370 rwhp / 381 ft lbs ![]() ~Tuned by JJ at WMS ![]() "Like the blind man says......We shall see...."
#10 | |
O wow I didn't know that! ill try that tomaro morning hehe thanks!
2001 Cobra
14.2@102 (I suck)
did it work? just curious...
Umm it seemed to a little it didn't take as long but just curious do I turn the key all the way and hold it without the clutch pushed in so it doesn't start or just all the way to on so everything turns on? And do I pump the gas when the car is in the on position to help it or just let it sit for a minute?
#13 | |
Safud: MM's Resident Hadji
So I turned it all the way on and left it for roughly 20 seconds. And yes it did help significantly. Just curious, do all you of you guys do the same to your cars before you start it? I had no idea that it primed the pump.
2001 Cobra
14.2@102 (I suck)
Well it sounds like you have a weak fuel pump or clogged/pinched fuel lines? Mine always starts right away
THANKS GUYS! ever since I let it prime for like 3 seconds or so she fires right up! Shweeeeet
i usually prime it if its been sitting for a while
Threads Similar to: Troubles Starting? HELP
| Starting troubles... | wyjeep | 99-04 | 9 | April 15th, 2009 03:39 PM |
| T-45 Troubles | 97GT4.6 | 96-98 | 12 | October 8th, 2008 04:12 PM |
| still have troubles | krispy | V6 Mustangs | 2 | July 14th, 2008 02:58 PM |
| I need some help please, I've been having some troubles... | Naytoo | General Tech | 4 | April 21st, 2008 05:21 PM |
| starting troubles?? | tBuck345 | General Tech | 2 | June 10th, 2007 08:55 AM |
