Coil packs
Old May 1st, 2009, 01:18 PM   #1
1999 Mustang GT
Regulator is on a distinguished road
Send a message via AIM to Regulator Send a message via Yahoo to Regulator
Coil packs
It seems Motorcraft lists a different coil pack number (DG512) for the 99 Mustang only, but the 00+ all have DG508. Do I HAVE to use the part number specific to my car or can I run the other part number without issues?
Also, is it best to stick with stock OEM coil packs or are any of the aftermarket versions good to use? I know when they first came out there was a lot of discussion about them going bad really fast, I didn't know if that was just a specific brand or if they are all like that.
'99 GT FS/FT. Click here for details!
"And I heard a voice in the midst of the four beasts, I looked and behold: a pale horse.
And his name, that sat on him, was Death. And Hell followed with him."
Old May 2nd, 2009, 12:18 AM   #2
Moderator
casper gt's Avatar
2010 mustang gt auto
casper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud of
Ive ran into some strange 1 year only stuff for 2000 also. IMO, I'd use pretty much any year coil-pack with out a second thought, but I have ACCEL coils on mine not with no complaints.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2010 GT auto
Old May 2nd, 2009, 12:24 AM   #3
1999 Mustang GT
Well after a lot of research today I found that it has to be year specific on the coil packs, the wiring harness connector accepts a thinner prong than is on the 00+ so if you try that it will probably mess some stuff up. I had a friend come through on a spare one and it seems to have cured the issue, but before I swapped them out it threw a code for the coil pack that sits right next to the coil pack that I knew was going bad. After I swapped out the known bad coil, it runs great again and haven't gotten any more CEL's.
Could that second CEL for the other coil pack have just been a fluke?
Old May 2nd, 2009, 12:48 AM   #4
Moderator
casper gt's Avatar
while I havent had the problem my self (knock on wood ) you may be staring to have that coil wiring problem that comes up on here occasionaly. cant quite remember exactly the problem but it has something to do with the wire insulation deteriorating in the loom & causing random coil problem's much like your describing (code's coming & going for no reason, along with driveablity issues) & eventually the car just wouln't start. mabie do a search on something like "coil wiring" or something like that.
2010 GT auto
Threads Similar to: Coil packs
coil packs ricks01 Modular Mustangs 11 July 13th, 2008 01:40 PM
When should you replace coil packs energiesource 99-04 24 July 6th, 2008 08:56 PM
2005-2007 Mustang GT 3V Coil Packs & Coil-on-Plug Connec ozan169 2005 - 2010 4 February 7th, 2007 10:03 PM
Help with coil packs 99modular 99-04 2 July 23rd, 2006 10:09 PM
