Supercharger and Nitrous Questions
Old January 25th, 2007, 08:48 PM   #1
Proud American
MustangMatt96GT's Avatar
Ok so when a supercharger is placed on a car, it is compressing the air that is already in the atmosphere right. Cuz right of the bat at sea level every car is running roughly 14.7 psi of air(that is the air pressure at sea level and at 25 degrees celcious. I was thinking that what if you just compressed oxygen so much that the engine ran better, kinda like nitrous, but that is roughly 80% nitrogen and 20% oxygen. If im not mistaken the only thing that helps the engine burn more effeciently is the oxygen in nitrous, so why not just use pure oxygen and not use nearly as much as nitrous? Well anyway i may be just out of my mind, but i have been wonding for quite a while nobody has been able to answer me.
Old January 25th, 2007, 09:04 PM   #2
WilltheThrill's Avatar
Saving up for another one
WilltheThrill has a spectacular aura aboutWilltheThrill has a spectacular aura aboutWilltheThrill has a spectacular aura about
What you're sayin makes sense cuz oxygen is one of the 3 elements required to make fire, Ive wondered too if it would help just shooting pure oxygen into a engine, lol
Yes those are cobra R replica mustang wheels on my 300zx
03 Cobra- gone but not forgotten
90 Nissan 300zx
00' Yamaha YZF 600
Originally Posted by '97'Cobra View Post
I was too drunk even tell which hole i was gettin after.
Old January 26th, 2007, 08:31 AM   #3
03 R Code's Avatar
unstoppable @ speed of light
03 R Code will become famous soon enough
This should help.
The advantage of nitrous is that the nitrogen acts as a combustion buffer, slowing the resultant pressure rise that occurs when the oxygen-enhanced air/fuel charge is ignited. This is why N2O is a far better choice than injecting pure oxygen. With pure oxygen, the resulting combustion process would be so violent that it would immediately destroy the engine. Even at the same power level, nitrous creates a much quicker cylinder-pressure rise than either a normally aspirated or supercharged engine. This is the big reason why nitrous engines demand less ignition timing. Optimal cylinder pressure should occur with the piston at roughly 10 to 15 degrees after top dead center (ATDC) to take maximum advantage of the leverage offered by the crankshaft as cylinder pressure pushes down on the piston. This is why over-advanced ignition timing, even in a normally aspirated engine, makes less power because the ignition begins the combustion process so early that the engine is working against cylinder pressure as the piston approaches TDC.
Old January 26th, 2007, 08:32 AM   #4
03 R Code's Avatar
This is where I found the article. There's a whole write up on there. Pretty informative.
http://www.chevyhiperformance.com/te...ide/index.html
Old January 26th, 2007, 07:44 PM   #5
Proud American
Thanks man its a great read! :wink
Old January 26th, 2007, 07:47 PM   #6
thats interesting, thanx bro
90 Nissan 300zx
00' Yamaha YZF 600
Threads Similar to: Supercharger and Nitrous Questions
more nitrous questions TTownZilla 99-04 63 September 7th, 2007 04:57 AM
nitrous questions gtdan 96-98 4 August 27th, 2007 08:46 PM
Nitrous Questions MustangMatt96GT 96-98 9 May 23rd, 2007 06:53 PM
NITROUS questions rkloehn 5.0 Mustangs 5 April 15th, 2007 10:48 AM
Supercharger or Nitrous? 94' Cobra 351 General Tech 42 February 22nd, 2007 04:18 AM
