Discussing a lil help plz in the Modular Mustangs Forum. i have a 98 gt and whenever i turn sharp it seems to make kind ...
Old January 28th, 2007, 03:40 PM   #1
a lil help plz
i have a 98 gt and whenever i turn sharp it seems to make kind of a clunking/skreaching/squeaky noise like obviously something isnt rite, has anybody had this problem be4 or any idea what it could be?
Old January 28th, 2007, 06:35 PM   #2
Something with the front suspension. Most likely a wheel bearing but could also be a ball joint or tie rod.
99 Dark Green Satin Mustang GT conv
K&N CAI; MAC O/R H-Pipe; Flowmaster 40s; FRPP 13lb flywheel; Motive 3.90s; Diablosport tuner; Eibach Prokit springs; Tokico Dspec shocks/struts
13.805 @ 100.23, 1.97 60'
Old January 29th, 2007, 03:24 PM   #3
Casper98GT's Avatar
tie rod ends and balljoints on these cars can make that noise.
Ford/Toyota tech.
-93 LX, X303 heads, F-cam, Trickflow u/l, 1.6 RR, FR wires, MSD cap/rotor, Elec. fan, a/c delete, smog delete, sn95 fuel rails with BBK regulator, 75mm TB and EGR, Vortech S-trim w/intercooler, 42lb inj/PMAS, 3.55's -
Old January 31st, 2007, 04:54 PM   #4
starman1950's Avatar
There are bushings on the tie rod ends too, check them 1st then proceed.....
God I love my GT !!!
Old February 1st, 2007, 12:22 AM   #5
Casper98GT's Avatar
Care to explain this one? How does a tie rod end have a bushing on it? A tie rod end is the end of the steering rack. Its made up of a steel threaded internally rod with a ball and socket end with a boot over it protecting the grease.
Ford/Toyota tech.
Old February 1st, 2007, 01:22 AM   #6
sorry not the ends..........my bad
Old February 2nd, 2007, 03:05 PM   #7
jagstang96's Avatar
I had that problem before and the first thing to check is the shock mount towers , open your hood and look at the mount c if u can tighten up the 3 nuts on the tower this was causing my problem they got loose and the shocks were not stable so when u turn it would create that crunk good luck.
