need info on springs and spring rates
Old July 8th, 2009, 07:05 PM   #1
01 mustang gt
13.98@100
1TITAN is on a distinguished road
i am hoping that some of you could enlighten me about the srings for performance driving. i notice that when you go to most websites that sell springs for a car they more often then not have a variety of springs with what they call different spring rates (for instance a 150lb, or a 200lb spring) that are measured in lbs.
i want to know to what effect do the weights adjust the performance of a vehicle? its always bugged me and i would rather know the reasons behind a choice rather then going into a shop and rely on their recomendation if you know what i mean
thanks for your time
destroy in the turns, then obliterate on the straightaway
01 GT
4.6/20 over
cold air intake/70 mm throttle body
mac longtube headers/custome H pipe/moroso spiral mufflers to side exhaust
computer tune
race seats / 5 point harness
Old July 10th, 2009, 01:27 PM   #2
ModMustang97GT's Avatar
1997 Mustang GT
Faster than an s4
ModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura about
ok, well. This is actually really simple. The spring rate is the amount of force required to compress the spring an inch.
For example, the force to squeeze your stock front spring is about 450 lbs. This means that with 450 lbs of force the spring will compress 1 inch, resulting in the wheel of your car moving about a half inch up.
Of course the ultimate goal with handling is to have the car 100% flat and completely spread on all 4 tires at all times. This means curving to the road surface without giving up much body roll and there by moving the center of gravity from the center of the car.
On our cars, the spring is actually working on a lever, your A arm in front and your control arm in back. This means that instead of your wheel rate being exactly the same as your spring rate, it is actually less. For example, the spring rate on your stock mustang is about 450 lb/in. And the loss of force is about 50-60%. This means that with stock springs, your wheel rate is going to be about 225 lbs/in. Which is pretty terrible. And in the rear the loss is slightly higher.
That is the stock spring rates. Coil over spring rates are 90% and 110% as effective on the wheel rate in front and rear respectively. Meaning, the front coil overs springs make 90% of their lbs/in to the wheels.
Hope this makes sense. Let me know if it doesn't.
Aztec Gold 97GT.
MM CC Plates, Panhard Bar, SFC's & Tower Brace
Eibach Sway Bars
H&R Race Springs/Bilstein Shocks
MAC CAI, LT's, Catted H and Pro-Dumps
KB Boost-a-Spark
04' PI Motor
Author of The Official Suspension Guide
Old July 11th, 2009, 03:58 AM   #3
01 mustang gt
13.98@100
that was quite helpful and you even covered coil overs before i could ask about em lol thanks
01 GT
4.6/20 over
computer tune
Threads Similar to: need info on springs and spring rates
Stock Spring rates ReverendDexter 4V / SVT 3 January 25th, 2009 09:05 PM
Labor Rates poisonstallion95gt 94-95 3 November 8th, 2007 01:24 AM
flow rates banned 99-04 0 July 21st, 2007 12:16 AM
Spring rates singe V6 Mustangs 4 July 17th, 2007 06:21 PM
Eibach Pro Kit Spring Set or Ford Racing K-Springs DaemonJ General Tech 4 February 11th, 2007 10:36 PM
