Spring Install
Old February 1st, 2007, 09:16 PM   #1
99redmustang's Avatar
99redmustang is on a distinguished road
Spring Install
Is installing springs a do it yourself job or should I take it to a shop and have someone do it. I'm taking the the horrible lowering springs that I bought the car with off and i'm goining to put stock GT springs on them for the time being. I have the tools but I've never done it. Any advice??? Thanks.
Old February 2nd, 2007, 09:01 AM   #2
ATLmustang is on a distinguished road
me and my dad did it on my car its not an hour project but it can be done. i was orginally going to try and use a spring compressor form like autozone but ended up just takeing everything apart. i had quote from kauffmen tire and they wanted i think 200-250 to do springs thats not bad as i look back on it. i would of prob paid someone to do it just b/c its like a good all day project with another person. its not impossible but getting the stock springs back on are prob gonna be a pain. just my .02
good luck
Old February 2nd, 2007, 04:25 PM   #3
Resident Bubblehead
00vabchgt's Avatar
00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough
you can do it yourself, no need to spend money on the labor. it'll take a few hours, but not all day.
Submariners Do It Deeper
Military Crew
MM1 (SS)
Order of the Bluenose
US Navy Veteran
Originally Posted by MamaStang View Post
"Boy Danny....nice cock ya got there. "
Old February 14th, 2007, 11:15 AM   #4
mightyb28's Avatar
mightyb28 is on a distinguished road
No sweat, just be careful on taking the stock springs out, the are longer and pop sometimes so get something to clamp them on a compressed positon. I installed my springs in 1.5 hours. No problem. Just get a 4lb sledge so you can get the control arm bolt off the A arm. You'll have to wack it hard for it to release or use a tuning fork to shake it free.
There are a bunch of articles for spring replacement on the web.
"Adding parts to your car DOES NOT make
it a tuner - Increasing performance DOES!"
- John Ginieczki
Old February 14th, 2007, 01:46 PM   #5
Resident Bubblehead
00vabchgt's Avatar
if you don't have a lift and are just doing it on jackstands, make sure you have the car jacked high enough so the control arm will swing low enough to let you pull the spring out. since it was my first time doing it when i did it on my car, it took me a day of fighting before i realized that i should just jack the car up higher. also, you don't really need a spring compressor, just put a floor jack under the control arm and let it down slowly. but if you want the warm fuzzy of having a spring compressor on the spring (not a bad idea) you can rent one from advanced auto or autozone. i just found that the compressor was more of a hinderance than help.
Military Crew
MM1 (SS)
US Navy Veteran
Old February 19th, 2007, 12:41 AM   #6
inthered03's Avatar
inthered03 is on a distinguished road
Send a message via Yahoo to inthered03
I just swapped out my stock 4x4 springs for a set of eibach sportlines. If you get good springs they will come with everything you need and tell you exactly what tools you need. Make sure and use the center pull style spring compresser because you can't get the side pull compressers 180 degrees from each other. Take the time and disconnect your caliper, strut, and front sway bar so your a-frame can swing down as far as possible. Your lowering springs will probably fall out of the rear end, you'll have to compress the front ones. You'll just have to wrestle the stock springs back home,.....better you than me.
**stroke'n**
Old February 21st, 2007, 02:53 PM   #7
StuTheMusicEngineer's Avatar
StuTheMusicEngineer is on a distinguished road
http://www.mustangworld.com/ourpics/...edaspring1.htm
real easy... i installed them with no problem....having never done a spring install before....check this link
2004 GT....4.10s, SCT X Cal2, BBK Lts, BBK O/R Xpipe, Flowmaster catback with Super 40 mufflers, BBK 75mm TB & Plenum, K&N Filter w/no silencer, Steeda UDP, Steeda TriAx, and Steeda G-Trac stages 1, 2, 3, and 4, blower is on the way!!!
Old February 21st, 2007, 03:30 PM   #8
mdvaldosta's Avatar
11.47@120.58
Didn't need to use a spring compressor or take off the a-arm. Just took the swaybar links off, then the tie rod, lower strut bolts and abs bracket, the just pushed the a arm down with my foot and popped the spring out with a prybar.
Old February 21st, 2007, 07:30 PM   #9
Proud American
MustangMatt96GT's Avatar
In that link on how to install the springs, it said something about german torqueing or something. I was just wondering what that is and how it is accomplished?
Threads Similar to: Spring Install
Spring ???? ShouldaTapt 5.0 Mustangs 0 September 8th, 2007 05:49 PM
Another spring ? 1LOUDGT 2005 - 2010 10 September 2nd, 2007 09:59 PM
Best spring set for a DD? TIM350 94-95 0 August 18th, 2007 11:04 PM
Spring kit lwhitetrash88l V6 Mustangs 12 April 24th, 2007 10:44 PM
99 3.8 cam w/spring install mmvi V6 Mustangs 5 April 24th, 2007 05:04 PM
