Hooo Ha Ha
Questions about Rims and milling.
I have a set of rims for my car.
They came off of a Toyota supra and are very nice. The bolt pattern matches up fine but the issue is with the hole in the center of the wheel. Its a few mm to small. Would Milling the center down a little with like a dremel destroy the strength of the wheel or will it be fine? |
another dahm ford
taking a small amount off is ok. as long as you dont need to cut like 1/2 in ouch. then you would be in trouble
![]() 97' 3.8 to 4.6 swap all stock 67' mustang gt coupe 88' ranger, just a clean ass truck 48' jeep cj2 the work hogg |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
+1
IBEATU
06 GT, 98 GT, & 93 Notch
try to get a good tight fit on the hub and you'll be ok
![]() 98 GT: some stuff 06 GT: more stuff 93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper Paxton/Vortech Crew Member #3 FRPP's #1 Dealer Injected Engineering BMR Suspension |
2000 gt
you could just take it somewhere and have them do it to make sure it's done 100% right.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tqHARDCORE CREW BRIGHT ATLANTIC BLUE CREW #1 MEMBER |
mm's nitrous mod
2000 mustang gt
where ever you take it is going to probably do the same thing anyway.
2001 Mustang Bullitt
8.61 in 1/8th mile
I have a 2001 bullitt, How much trouble is it to put Billet Specialities 15" to clear the brakes
2003 Mustang GT
post pics
#9 | ||
2007 REDFIRE VERT GT/CS
Had mine done for a different car (Mazda to Mitsu) cost $75 for all 4. Just try and keep the lip at the edge so the center cap still snaps on. If possible, of course!
![]() FRPP Whipple HO, FRPP 4.10, Magnapacks, SSC springs, BMR adj. panhard bar, Hurst Billet STS, 285-40-18 / 255-45-18 BFG T/A
Threads Similar to: Questions about Rims and milling.
| Are PI Heads better than milling my heads | 96redGT | 96-98 | 7 | April 30th, 2008 04:10 PM |
| Milling / Shaving The Head | hellion_79 | 2.3 Mustangs | 12 | November 17th, 2007 12:42 AM |
| CNC milling machine | texas_mustang | 99-04 | 15 | June 8th, 2007 12:10 AM |
| friend just got a CNC milling machine | texas_mustang | V6 Mustangs | 13 | January 26th, 2007 05:59 PM |
| how much does it cost to install forged internals? milling? | via sin dios | V6 Mustangs | 21 | January 12th, 2007 08:46 PM |
