My Battery dash indicator
Old August 4th, 2009, 04:36 PM   #1
tmoney78's Avatar
1998 Mustang Gt 4.6 v8
tmoney78 is on a distinguished road
Question
Hey everyone,
sometimes when i don't drive my stang for like 3 day and then when i turn on my car after all those day the battery indicator goes up and down for a few seconds, and after is running for 10 minutes is goes back to the middle?
has anyone had this problem before?
thanks you all in advance
4.6 custom Plenum ported
K&N Air Intake
75mm throttle Body
Bassani X pipes
40's Flowmaster
18" Axis Blck and Chrome
Old August 5th, 2009, 01:03 PM   #2
mmikeclass06's Avatar
another dahm ford
mmikeclass06 is on a distinguished road
ive never heard of it. only think pops in mind is regulator maybe?
97' 3.8 to 4.6 swap all stock
67' mustang gt coupe
88' ranger, just a clean ass truck
48' jeep cj2 the work hogg
Old August 5th, 2009, 10:42 PM   #3
tmoney78's Avatar
Oh ok well I just intall fuel rails and adj regulator, I was thinking altenator buri took it o autozane and they said it tested fine. My car does have high miles and I have never change my altenator. I'm not sure what it could be maybe baterry but is like 2 years old
thanks I guest , and do you know what psi the regulator should be at because my fuel gauge shows it at 22 when the engine is on and it foes up to 40 psi when I give it gas?
K&N Air Intake
75mm throttle Body
Bassani X pipes
40's Flowmaster
Old August 6th, 2009, 12:40 AM   #4
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
if they tested it at AZ then its good. i would have them check the battery or you may just have a faulty gauge. as far as your FP i think that its about right I want to say that it is like 25-30 delta @ idle or something like that, someone correct me if im wrong.
BUILD 2 IN PROGRESS
Threads Similar to: My Battery dash indicator
Dial Indicator for Cams 98midnight 99-04 4 August 3rd, 2009 05:10 PM
Overdrive Indicator light blinking ICFlash 99-04 6 January 15th, 2009 12:44 AM
Turn Indicator Replacement phazedragon Audio/Video 4 April 7th, 2008 03:12 AM
AOD Shift Indicator LikeYouStoleIt V6 Mustangs 2 December 27th, 2007 06:11 AM
battery light on dash... 1990CA50 5.0 Mustangs 6 February 3rd, 2007 01:02 AM
