tubular front suspention
Old August 5th, 2009, 05:59 PM   #1
mmikeclass06's Avatar
another dahm ford
mmikeclass06 is on a distinguished road
what advantages other than weight loss is there with going to all tubular front suspension? my gt that is about to be full stripped down and restored, all ready getting cobra irs and was thinking of upgrading the front also, mainly because the body had 300k on it when i pulled the v6 out and put in the 4.6, front is getting really load when i turn so i been wondering to just rebuild the one i have or spend money and buy all tubular with new bushings (planning on turbo in near future when 5.4 is finished being built, also where/what would you recommend. ONES who have
97' 3.8 to 4.6 swap all stock
67' mustang gt coupe
88' ranger, just a clean ass truck
48' jeep cj2 the work hogg
Old August 5th, 2009, 07:45 PM   #2
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
ndfrspd is infamous around these parts
you mean tubular front k member?
"The only way to learn about a car truly is to break something and fix it yourself..."
Old August 5th, 2009, 07:49 PM   #3
DejaBlue87's Avatar
95 gt
DejaBlue87 is on a distinguished road
with the k member u will have more room also
Old August 5th, 2009, 08:11 PM   #4
ModMustang97GT's Avatar
1997 Mustang GT
Faster than an s4
ModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura about
Well, with the tubular front, you are going to be shaving about 35-50 lbs off the front. A good thing, since you are adding 50 lbs of weight with the 5.4l.
You will get better geometry due to the new K member being designed for the drop height that you will generally be running.
You will need to get Coil-Overs with the K-member. Coil overs will save you weight and give you better handling. But it isn't that cheap. The K member kit with the Coil overs included will runn you about $1500 from Maximum Motorsports. Less with a granatelli, or QA1 piece.
What kind of driving are you planning to do with this car? Daily Driver? Drag queen? Twisties? AIX? This will give us a good idea of what kind of K member would be the best bet.
You should get Subframe Connectors either way. This will distribute the work of the suspension through out the rest of the car.
Aztec Gold 97GT.
MM CC Plates, Panhard Bar, SFC's & Tower Brace
Eibach Sway Bars
H&R Race Springs/Bilstein Shocks
MAC CAI, LT's, Catted H and Pro-Dumps
KB Boost-a-Spark
04' PI Motor
Author of The Official Suspension Guide
Old August 5th, 2009, 08:53 PM   #5
another dahm ford
its going to be a weekend car that will maybe see track once a year if that. just wanting to see what others would do. main reason i was thinking was room for piping down the road. and if im redoing the rest of my car why not touch it too.
Old August 5th, 2009, 09:02 PM   #6
Bearer of Bad News
Fluffy The Rhino's Avatar
I has mustang and legacy.
Slower than my Ruger.
Fluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to behold
A tubular K member is in my future. I'm just looking forward to having more room.
~MOD NUTSWINGER~
My Tongue Soothes Razorburn
STOPSAYINGFAIL.COM
EVERY FART IS A GAMBLE
Just Think Of Me As A White Blood Cell.
Old August 6th, 2009, 03:16 PM   #7
01 mustang gt
13.98@100
1TITAN is on a distinguished road
i had been lookin at the QA1 set up and i think eventually thats what i want to get total with the k member replaced and the control arms and running the coil overs all that equals out to about 70lbs. (roughly) off of the fron of the car. some of that will be unsprung weigh which will have a little more effect on the handling and response of the car.
if your rebuildin the entire car i would go ahead and do it, it would defenitly change the attitude of the car all round
destroy in the turns, then obliterate on the straightaway
01 GT
4.6/20 over
cold air intake/70 mm throttle body
mac longtube headers/custome H pipe/moroso spiral mufflers to side exhaust
computer tune
race seats / 5 point harness
Old August 6th, 2009, 03:30 PM   #8
98Cobra_sleeper's Avatar
1998 mustang cobra
98Cobra_sleeper is on a distinguished road
I have a Qa1 tubular kmember and coilover kit, and it's a nite and day difference with room and weight. i paid 540 shipped from an ebay store called 'uprproductsonline. I had to get this kit because i bought a twin turbo kit, and the kit was designed around that kmember. Its worth it to go ahead and do it now. everything fit really well, and i felt the money was well spent.
Old August 6th, 2009, 07:13 PM   #9
1997 Mustang GT
Faster than an s4
The only thing I would say regarding the QA1 or Granatelli, is the strength is not as high as the Maximum Motorsports or a few other options. However, the cost is alot different. If this is an average car. Not pulling the front tires 2 feet in the air, not pushing 600 rwhp, not doing high speed track driving. The QA1 and Granatelli pieces should be plenty strong. I just personally really like the Higher Quality pieces, because I want to think it will make a difference to me (don't burst my bubble).
The added difference in space is HUGE. The stock piece is total crap, and has nearly no where to get around the engine. The Tubular pieces are HUGELY better for access. Put it this way. With LT headers, if you don't have the tubular K member, you have to either jack the engine up about 6 inches, or drop the K-member completely to even get at the header bolts.
Either way, the difference in handling will be huge, and the weight gains will be awesome. I'm not sure about 70 lbs. I have heard as high as 60, but that was still suspect and with a Granatelli piece (really light/possibly weaker).
Aztec Gold 97GT.
Eibach Sway Bars
KB Boost-a-Spark
04' PI Motor
Old August 6th, 2009, 07:34 PM   #10
Bearer of Bad News
I know the PSR K-Member shaves 71 or 72 lbs. off of the stocker. I've also read that the tubular K makes for a stiffer ride. A small price to pay for weight reduction, ease of maintenance, etc...
~MOD NUTSWINGER~
STOPSAYINGFAIL.COM
Old August 6th, 2009, 07:56 PM   #11
1997 Mustang GT
Faster than an s4
I question those weight differences. I have yet to see someone come out to those numbers. They claim those weight differences on their web sites and crap. But the people that I have heard that actually weighed it all out only seem to come up with 35-40 lbs differences. Not that its not possible, just haven't seen it yet.
Aztec Gold 97GT.
Eibach Sway Bars
KB Boost-a-Spark
04' PI Motor
Old August 6th, 2009, 08:00 PM   #12
2009 ROTY
AzSonicSnake's Avatar
2003 SVT Cobra
11.07@127
AzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud of
Send a message via AIM to AzSonicSnake Send a message via MSN to AzSonicSnake
exactly. and i run the exact same k-member. its been on the car for about 2 years now, and i would say its one of the best mods i have done to the car to date. certainly made the feel of the car more tight, and not so sluggish imo. plus when i put my line lock on i thanked god that i had it because it made the install soooooooooo much easier. its worth every friggen penny.
MM Cobra Club #25 My Autolog Profile
Old August 16th, 2009, 02:59 AM   #13
86er's Avatar
86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold
dont leave out how maximum makes their K members for road racing, of course its going to be stronger than the others. Its also heavier than most other K members on the market. They put more bracing and supports for the lateral movement and weight shifts
There isnt a single thing wrong with a qa-1 k member. I have seen them on stock fox bodies and 1200hp cobra's
Just a truck
Old August 17th, 2009, 01:22 AM   #14
1997 Mustang GT
Faster than an s4
How many of those 1200 hp cobra's are daily drivers? Daily driving gives a lot of forces that drag racing does not. Also, alot of thoes cars probably break them and replace them cause they are cheap.
The point is, I know that the Maximum Motorsports pieces are some of the best pieces out there. QA1 does very well, but the fact that they seem to survive is not a good enough reason to justify it.
Your car also makes good power without the air filter on it, but that doesn't make it a good idea.
Aztec Gold 97GT.
Eibach Sway Bars
KB Boost-a-Spark
04' PI Motor
Old August 17th, 2009, 02:22 PM   #15
86er's Avatar
actually I can think of 3 that are driven 300+miles a week actually.
If qa1 is under a car, dont be second guessing yourself oh I should have bought a maximum one or someone elses. It will do just fine
Just a truck
Threads Similar to: tubular front suspention
94 Gt Tubular Front End Nev3rL1ft89 94-95 6 December 15th, 2008 11:33 PM
BMR Fabrication Front Antiroll Bar Eliminator/Tubular Lower Draztic1 2005 - 2010 2 September 30th, 2007 12:00 PM
tubular front kmember Invictus 99-04 3 June 23rd, 2007 08:50 AM
Front End Suspention stang94 5.0 Mustangs 5 December 21st, 2006 11:08 AM
