Discussing cams and gears question in the Modular Mustangs Forum. cams and gears I just realized this but would getting like stage 2 or 3 ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
cams and gears questionI just realized this but would getting like stage 2 or 3 cams in the high RPM's and then getting gears like 430 or whatever.. Since you rev higher you would see more hp farther up in the RPM's, and a shit load better acceleration, but since you can rev higher and have more power higher in the rpm band would your top speed maybe go up or stay the same even with like 4 56 gears.. I am just trying to understand the whole concept.. anyone want to explain it to me lol.. like how gears and cams work together.. sorry if you dont understand the question lol
95 ' v6 Mustang, 5 Speed. |
Location: Greeley Colorado with high rate of living an low wages baby!
If you have a shorter gear ratio you will be able to utilize the higher rpms better. But you will lose a negligable amount of top speed. Going for stock gear ratio to something like 3.73's is going to lose you only about 10-15mph.
But with a camshaft that say has a powerband range of 1500-6000 that is just where the camshaft will have peak flow. So more high end power you should have a shorter gear ratio then say if you had a powerband of 1000-5500. It's just about getting a good middle ground for both of the modifications. Oh and shorter gears do not give you any more horsepower. In fact you might even lose 1-2 rwhp with really short gears like say 4.56 due to all of the extra friction that is caused from the extra rotation of the rear end gears. Any questions, or did I miss anything? |
k, i kind of understood everything before, but this clarifies a bit..
Threads Similar to: cams and gears question
| Pi Cams And Gears | ujslost | For Sale | 5 | November 10th, 2007 09:09 AM |
| cams and gears | Bhblondguy | 2005+ | 4 | August 23rd, 2007 12:40 AM |
| Question Regarding Cams | Bigb2000GT | 99-04 | 3 | March 26th, 2007 05:13 AM |
| PI Cams With or With Out Pressed Gears? | tlgrant | 96-98 | 4 | November 2nd, 2006 06:54 PM |
| sweeeeeeeet!!! got my new toys (headers, cams and cam gears! | drgnracin72 | Multimedia | 7 | July 5th, 2006 04:44 PM |
