Useful info from StangSuspension
Re: what shocks and struts worked best with a lowered Mustang
Only for Tokico, Koni, or KYB do you have to get the 87-93 struts on lowered Mustangs. These brands use internal bumpstops which can get damaged if you use the newer struts. For Bilsteins, it is not necessary... you can use the 94-04 struts/shocks. Sincerely, Josh Sadowsky StangSuspension.com http://www.stangsuspension.com |
nice info thanks for sharing
I dont get it ?
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
if you have an already lowered mustang, meaning you put lowering springs on it-and you are going to replace your shocks/struts, if you buy anything BUT Bilsteins it is recommended to order for a Fox Body instead of a 94-04.
and this is supposed to be due to the internal bumpstops? So there is a problem with everyother Mustang on the road that uses these struts ? I have put countless shocks and strut combos in Mustangs and never had problems.
#6 | |
I understand.
Threads Similar to: Useful info from StangSuspension
| just some info | Iownastang | 5.0 Mustangs | 1 | July 10th, 2007 08:15 AM |
| Would like some info. | acmillr | 99-04 | 8 | June 15th, 2007 03:22 AM |
| Help.. I need Info. | JBIGBOOTSY | 5.0 Mustangs | 2 | February 28th, 2007 08:44 PM |
| Info | sgb1 | 5.0 Mustangs | 11 | January 11th, 2007 01:12 AM |
| Partshopper.com & Stangsuspension.com | stangliter04 | Vendors | 0 | May 30th, 2006 03:36 AM |
