i need to talk to the 4r70w experts here lol
Old August 19th, 2009, 02:08 PM   #1
01 mustang gt
13.98@100
1TITAN is on a distinguished road
i want to know why they say you should not use o/d while racing?
why is it bad to shift these transmission into 4th under wide open throttle?
is there a way to strengthen them to where i can use 4th (overdrive) for racing?
(reason being is i am going to be getting back into autcrossing and road course racing and being minus a 4th gear could put damper on my straight away performance if ya know what i mean)
any advise yall have would be musch apprieciated
destroy in the turns, then obliterate on the straightaway
01 GT
4.6/20 over
cold air intake/70 mm throttle body
mac longtube headers/custome H pipe/moroso spiral mufflers to side exhaust
computer tune
race seats / 5 point harness
Old August 19th, 2009, 07:16 PM   #2
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
biggest problem is the o/d band & torque converter clutch (not to mention the o/d gear ratio). should find lot's of info here Click Click Racing Forums - Powered by vBulletin
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old August 20th, 2009, 03:31 PM   #3
01 mustang gt
13.98@100
ehh i have to register with the site to view that link. thanks anyways
01 GT
4.6/20 over
computer tune
Old August 21st, 2009, 08:14 PM   #4
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
what's wrong with registering for a web site that'll sort out your trans problem's?
2012 300a GT auto
Old August 28th, 2009, 09:44 PM   #5
Silverfoxbody's Avatar
Silverfoxbody is on a distinguished road
Send a message via MSN to Silverfoxbody Send a message via Yahoo to Silverfoxbody
The only thing holding OD is a 2" band and the smallest direct clutches. The OD shift also drives half the heavy internals in the opposite direction in a split second - it just is not designed to hold the power like this.
You can obviously modify it to use OD at your command, but I don;t condone it with any power so to say.
Old August 30th, 2009, 11:47 AM   #6
01 mustang gt
13.98@100
ohhhh i see,.... yeah ive already blown an overdrive before.
so then does it sound like i should go with a standard aod instead?
if so then does any one know what all intales swaping an aod in place of the 4r70w?
how sturdy are the aod transmissions by comparison?
01 GT
4.6/20 over
computer tune
Old August 30th, 2009, 01:43 PM   #7
01 mustang gt
13.98@100
ive got some concerns after doing a bit of research into the aod... from what i understand ( please correct me if im wrong) the aod is in many ways the same as an aode except for the fact that its not electronically controlled, does this mean that it has the same flaw in the 4th gear as an aode does?... if so then does any one have a better suggestion.
01 GT
4.6/20 over
computer tune
Old August 30th, 2009, 04:15 PM   #8
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
an aod is far inferior to a 4r70w (ie. weaker) plus it wouln't bolt up to your motor (they never made an aod with a mod motor bellhousing). my sugestion is to set the car up to do what you need with 3 gears, using the extremely broad rpm/powerband capabilities of the 4.6 (built right they can be spun to ridiculusly high rpm's)
2012 300a GT auto
Old August 30th, 2009, 04:44 PM   #9
MM's Ford Truck Guy
FX4DTUF's Avatar
99 ranger,2010 ranger
does nice burnouts
FX4DTUF has a spectacular aura aboutFX4DTUF has a spectacular aura about
i think they make bell housings for c4's and c6's for 4.6's i cant remember where i seen them at but ill search
1999 xlt 2.5 ranger lowered 5/6 on 17in bullits
2010 4.0 xlt ranger lowered 4/5 on 18in dd bullits
Old August 30th, 2009, 04:55 PM   #10
silverstang's Avatar
2007 Mustang GT
silverstang is a jewel in the roughsilverstang is a jewel in the roughsilverstang is a jewel in the roughsilverstang is a jewel in the rough
Why not go with a 6 spd? Don't tell me you can't shift one yourself. If your autocrossing ALOT you would have to be semi-retarded not to consider one. 99% of real road racers run a manual anyways. You won't be putting up with ANY of this auto BS either. Now if this was a drag car, I would say stay with the auto. In your case you NEED a 6 spd.........Lots of options too. TR6060 is a good one to think about.
Bassani Crew Member #3
Old August 30th, 2009, 08:24 PM   #11
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
+100000000000 but the o/p has stated many time's in previous post's the he want's to stick with an auto for his need's . I hate to tell anyone to take an auto out but in this case it might be the best bet.
2012 300a GT auto
Old August 30th, 2009, 08:32 PM   #12
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Honestly, for autocrossing and road racing, the only reasons I can see to stick with a manual over a built automatic are weight and slightly less drivetrain loss.
On the courses I'm on, I don't even shift... just jam it in 2nd and leave it there. Of course, having 6800 rpm to play with and 3.27s makes that easier.
O o
/¯/______________________
\_\
Old August 30th, 2009, 08:46 PM   #13
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
I though the same a few thread's ago by the o/p, but he's talking about open coursetype road racing (ie. sears point/etc) not closed course. while being a drag racer I don't pretend to know much about road racing stuff, but for what he want's I can't really say an auto is gonna work or be easy to sort out.
2012 300a GT auto
Old August 30th, 2009, 11:54 PM   #14
2007 Mustang GT
an auto is NOT the best option for his type of racing, period. You want the car in the gear YOU want it in. Sometimes an auto doesn't "think" like you do, leaving you in either too low of a gear or too high of a gear..........(you know the feeling when you WANT the car to downshift but it wont?) ALSO with a nice 6 spd you have a WIDE array of different ratios at your fingertips, not so much with the 3 usuable gears with most automatics. I'm not being a dick, just stating the obvious.
Old August 31st, 2009, 12:03 AM   #15
Okay, so if you had a 6-speed auto with a manual valvebody that would address both of the issues you bring up. The automatic in the 370Z is a 7-speed with a manual-shift mode (using paddle shifters), so it's not like these systems don't exist.
O o
\_\
Old August 31st, 2009, 12:34 AM   #16
2007 Mustang GT
yeah that would work..............but find me a trans like that to bolt up behind these cars LOL............and I STILL wouldnt want to mess with an auto with a MVB....My friend has one in his 02 GT..........pain in the ass if you ask me, more work than driving a stick car LOL...........flippin switches for the convertor, etc....
Old August 31st, 2009, 01:20 PM   #17
01 mustang gt
13.98@100
yeah i hear yall ive been toying with the six speed idea as of this post, but just hearing some people hating on my automatic and then bitchin about it later just helps me get up in the morning lmao.... i just dont understand the whole elctronics aspect of it all (especially that weak ass over drive)... and yeah i manually shift the car so its not like im at a disadvantage in the turns...........
sigh im just sourcin ideas, in which case yall have been extremely helpful and i appreciate it alot
01 GT
4.6/20 over
computer tune
Old September 1st, 2009, 08:57 AM   #18
330CubeGt's Avatar
1997 SVT COBRA
1996 Mustang V6
330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light
iTrader: 14 reviews
Like Casper said i dont want to be the one to tell you to take the auto out but it might be in your best interest to go 5/6 speed.
-04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI-
Old September 1st, 2009, 09:18 AM   #19
01 mustang gt
13.98@100
yep thats what its sounding like..... i was lookin at all the performance rebuilds for the auto a while back and i think its funny as hell that they have a kevlar replacment band for over drive lol
you mean to tell me that the replacement overdrive band can take a bullet but it cant be used for racing lol
01 GT
4.6/20 over
computer tune
Old September 1st, 2009, 09:37 PM   #20
330CubeGt's Avatar
1997 SVT COBRA
1996 Mustang V6
iTrader: 14 reviews
No it can be i have seen people do it,Its just not the Ideal thing to do.You want to be at the top of 3rd going through the traps
They got some carbon fiber parts to.
LoL For about $600 ish in parts and me doing the labor i could have a auto that could handle almost anything i could throw at it,thats why i went auto.
Threads Similar to: i need to talk to the 4r70w experts here lol
C4 Experts Please Help! e3sean 5.0 Mustangs 8 April 26th, 2009 10:32 PM
Any Tv experts out there? GTblackprodigy The Clubhouse 25 December 5th, 2008 02:54 PM
Google Experts Come Hither... 1FastFox The Clubhouse 5 September 26th, 2008 07:02 PM
HELP PLEASE YOU EXPERTS sniperrider 5.0 Mustangs 21 October 13th, 2007 10:57 PM
Let's talk about rear-ends...lol postie V6 Mustangs 34 January 5th, 2007 02:32 PM
