97 Cobra SC loss of power need help
I recently had my 97 cobra rebuilt and supercharged using a vortech S-trim SC, the engine was rebuilt using diamond pistons, new rings, bearings, APR head bolts ect, ect. I went with a 255 fuel pump, 42lb injectors, ford motorsport ceramic shorty headers, bassani x pipe, and a set of flowmasters. the car ran fine for a few weeks only made a few short trips in it as it is still being broken in but the other day it lost fuel pressure, and oil pressure and just died on me and then would not start. the engine would not turn over at all making me think it was an internal problem. I had it towed home and the next morning it started up with a little hesitation and ran fine in my driveway but when I took it out for a spin around the block it had no power at all and died after maybe 2 blocks, doing the same thing, losing all pressure and shutting off. it started back up and as long as i kept the RPM's up it stayed running but again no power. there is no fluids leaking, no smoke, and no noises can someone please give me a few ideas as to what to check? I have been through everything I can think of "which isnt alot" and have gotten nowhere
2001 Cobra
14.2@102 (I suck)
you had it tuned, right?
![]() 2001 Cobra with SRA swap, modded for twisties ![]() MM Cobra Club Member #76 |
Yes, I had the car custom tuned.
03 gt, 95 740i, 96 disco
![]() ![]() iTrader: 2 reviews
bad head gasket sounds like...wont necessarily have smoke from that, friends truck did the same thing, was literally hydrolocking a couple cylinders and killing the engine, after a bit it would fire right back up.
if thats the case whats the best way to find out without breaking everything down?
simple, buy this tool. its probably the one tool that can save you from a major headache when buying used cars and a quick and easy diagnostic tool to test your own. i've used mine more times than i could remember looking for cars, on friends cars, when i was a mechanic, its a great tool.
![]() Air Conditioning, Leak Detectors | Matco Tools Online Tool Catalog 2nd tool down.
Threads Similar to: 97 Cobra SC loss of power need help
| Power loss... | 1sl0w88 | 5.0 Mustangs | 17 | July 12th, 2009 11:15 PM |
| power loss | Elder | 4V / SVT | 8 | September 8th, 2008 03:31 AM |
| power loss | 03Gtmustang | 99-04 | 13 | September 6th, 2008 12:16 AM |
| Could This Cause Loss Of Power | VSR13 | V6 Mustangs | 24 | December 14th, 2007 10:08 AM |
| power loss? | xedubx | 99-04 | 16 | June 20th, 2007 09:52 PM |
