New 18 inch rim question...18x9 front & 18x10 rear
Old February 11th, 2007, 04:56 PM   #1
Zippy's Resident Milf
tinkerbell_too's Avatar
2003 Mustang GT
February 2011 ROTM
tinkerbell_too is a splendid one to beholdtinkerbell_too is a splendid one to beholdtinkerbell_too is a splendid one to beholdtinkerbell_too is a splendid one to beholdtinkerbell_too is a splendid one to beholdtinkerbell_too is a splendid one to beholdtinkerbell_too is a splendid one to behold
So after getting no sleep last night trying to figure this out and not getting many answers from anyone on offset, I think the rims that I wanted to do come in the right offset.
OK...2003 GT....I went to americanmuscle.com and actually really like the FR500's in anthracite finish. As in my title, I want the 18x9's in the front and 18x10's in the rear.
For the rear, Im going to put 285/35/18.
Here's my dillema: I'm about to put Eibach Sportline lowering springs on it....they say they will create a 1 3/4 to 2 1/4" drop. I would like to get both the wheels and tires from americanmuscle.....the smallest they have for the 9" rim are 265/35/18.
Am I going to scrub up front??
Old February 11th, 2007, 07:57 PM   #2
mdvaldosta's Avatar
11.47@120.58
As long as you keep the stock tire height on the front and it shouldn't. I dropped about 2" in the front (by accident) and it only scrubbed when turning hard, though I had soft springs.
Old February 11th, 2007, 09:43 PM   #3
booooost'd
Jucostud's Avatar
2007 Mustang
Jucostud is a name known to allJucostud is a name known to allJucostud is a name known to allJucostud is a name known to allJucostud is a name known to allJucostud is a name known to all
35 is too small of a sidewall for your car. You should be getting 285/40/18. 35 is what you'd get if you had 20's
Jucostud's Official Build Thread
I'm selling everything off my car, if i have something u want, pm me.
1988 lx 5.0 - Daily
2007 vortech gt - for sale
2012 mustang 5.0 - December 2011
Old February 12th, 2007, 03:25 PM   #4
donny82277 is on a distinguished road
I have 18x10's in the rear and I went with 285/35 18s and I'm not happy with them. The sidewall curves too much, you need wider tire, i would suggest at least a 305 or maybe a 295
Old February 14th, 2007, 11:06 AM   #5
mightyb28's Avatar
mightyb28 is on a distinguished road
BS!!! Unless the roads, where you live, are rough and pot holed, 35's are just fine. I run 40 sidewalls and Denver has shit roads.
Yes on the 18x9 front and 18x10.5 rears. Just the best performance setup and what Saleen also does. I run 245-40-18 front and 275-40-18 rears. 280 will fit a lot better.
To cover the drop spring issue, I have a 2" drop on my GT and zero problems with clearance with the tires. Your only issue will be with speed bumps with your drive.
Finally, make sure you upgrade your S/S and control arms if you are changing springs. Might as well get it all done at once and done right.
:award
"Adding parts to your car DOES NOT make
it a tuner - Increasing performance DOES!"
- John Ginieczki
Old February 15th, 2007, 12:19 PM   #6
Slicey is on a distinguished road
Send a message via MSN to Slicey
The only shitty thing about 10 in the rear and 9 in the front is you cant rotate your tires and that sux if you like to hotrod like me.
Make sure to get your alighnment done if you drop it more then 1.5 inches lol. Inner tire wear sux.
Official MM Zeppelineers. Crew member #3
Old February 15th, 2007, 12:57 PM   #7
franchise's Avatar
franchise is on a distinguished road
I got the black fr500's from american muscle and have had no problems with the rear 285/35/18 (10 inch) and the front (9 inch) 265/35/18 with the sportline drop and the roush stage 3 kit. I have no problems at all. I am very happy with them, the tires fill up the wheel however I will prob go to 295's next time.
Old February 15th, 2007, 10:02 PM   #8
True2theHorse is on a distinguished road
I have a 97 Cobra with the Eibach sport liness adn the FR500's , 9's up front 10.5's out back no problem at all, I run 285/35/18 in back and 265/35/18 up front, I love it, and the ride is actually pretty smooth. I have no issues with rub at all. And the stance is perfect.
Just an FYI, don't forget the caster camber plates, they are a must. I installed mine on the same day for the perfect alignment and as stated it is great.
Hope this helps.
Threads Similar to: New 18 inch rim question...18x9 front & 18x10 rear
18X9 front and 18X10 bullit deep dish fit on 79-93? hitorx 5.0 Mustangs 2 March 28th, 2007 07:01 AM
