Discussing Big Problem in the Modular Mustangs Forum. i need help or advice because my car is lagging bad. its a 2000 GT, ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Big Problem |
Did you say the problem occured after you took off the iac.If you did,did you replace the gasket and what did you clean it with?If you used carb cleaner that will cause it to stick.Also it possibly be o2 sensor.it sounds like it is happening whe the car goes into closed loop.Give me some more info and i can help you.
yeah it occured after i cleaned it. i was on another forum and a guy told me to use ether on it so thats what i used. and no i didnt replace the gasket because it was in good shape.
but sometimes after i run the car when i have to stop at a redlight or stop sign the car will almost quit when it goes to idle.
like i said before, i dunno what happens when the engine is cold but it runs perfect until about 3 or 4 minutes of running it and then it goes back to stuttering around and jerking when i get on the gas
Sounds like it has a lean mixture issue, try checking the MAF sensor and see if it needs cleaned. The computer while the engine is cold will run it rich until the sensor tells it that it's warm. So it's after this point that your having the problem. Could be something as simple as a vaccum leak. So i'd tend to start looking in that direction.
DISABLED VETERAN LOVER OF ALL THINGS FORD SMITTEN BY THE MUSTANG |
plugs maybe. take it to a goodyear or somewhere with a good diagnostic tool. not the autozone thing. it will monitor the cylinders for missfire. and will monitor fuel to see if its lean
97 Mustang GT, MAC CAI, Underdrive Pulleys, Flowmaster Exhaust, BBK Offroad H-Pipe, 3:73 Gear, Autologic Chip, B&M Short Throw Shifter, Centerforce Clutch, Msd, Eibach Sportline Springs |
#1 Asshole Mod
i think it might be a 02 senser issue also, the question is when you actually floor it does it run fine cause thats when it goes into open loop and then when you are just driving normal it studders, cause mine is doing the same thing now and i need to get underthere and see if i burnt one of my 02 sensors on my headers.
![]() 99 Mustang GT VT 302 Stroker (race car) 11.13@123 for sale 9k 06 Dodge MegaCab. Cummins diesel power. Diablosport Powerpuck, Silencer ring removed, intake baffling mia, Isspro pyro, boost, and tranny gauges, 6inch chrome tip |
even when i do floor mine it still stutters its like it isnt getting enough gas or something.
but my check engine light isnt on or anything
#1 Asshole Mod
i say check your plugs first, i am guessing you don't have a cowl hood, cause water would get it my engine bay when i rained and get down inside my cop and cause a misfire till it dried out
When the car is warm take the iac off and see if it is opening.You should not use ether to clean any parts on the intake they are coated and the ether strips it off.Use 3m throttle cleaner it cleans and lubricates and doesn't harm the coating.What happens is the carbon was cleaned off and when it heated up it crusted the iac closed enough to have a good idle when cold as it warms up it doesn't have enough air to breath.Replace the iac and gasket clean the intake side and throttle with 3m throttle cleaner only!
how many miles?
if 50k+ and you never changed your coil pack. then thats your most likely answer |
2000 mustang gt
12.01@114.69
i have 85k with stock coils. i agree with the ether and coating issue, but another thing i would look at is the fuel filter.
stock long block, bolt ons, slicks, and a little squeeze 1/4 E.T. 12.06@114.69 ![]() Only two defining forces have ever offered to die for you: 1. Jesus Christ 2. The American G. I. One died for your soul, the other for your freedom. |
ok i replaced my iac and gasket but the problem is still there. now my engine sounds really loud, louder than usual and my exhaust tone has changed drastically. my exhaust sounds crackling and my engine just gets really loud and shitty sounding. any ideas on what that could be?
and when i give it gas it sounds like it just revs really high and get really loud but my clutch isnt slipping or anything. i cant figure it out at all.
#17 | |
Maybe you threw a rocker
White99stang-
93 LX, H/C/I + Vortech |
Threads Similar to: Big Problem
| umm have a weird problem? idle problem? | blue03mach1 | 99-04 | 16 | March 4th, 2008 12:03 PM |
| Has your car ever had a problem? | JASonic | The Clubhouse | 17 | September 19th, 2007 05:19 PM |
| big problem need help | 96gtponyred | 96-98 | 12 | August 22nd, 2007 01:36 AM |
| RIM Problem and Help | trueballerisme | 2005+ | 70 | August 21st, 2007 08:55 PM |
| TPS Problem? | 88Horseman | 5.0 Mustangs | 11 | November 13th, 2006 11:46 PM |
