Tree Fiddy Z
a lot of work ahead of you....
2003 Azure Blue Mach 1
4,000 miles on the ODO
different motor mounts im almost sure of it and ecu and lot of other things as well id just do a 4V swap instead of the 3V off a 2007 you will make more power with the 4V and everything goes in alot smoother plus it will probably cost the same for the 4V as the 3V..... and you will be spending alot of extra cash on fabrication on the 3V that could go to modding the 4V just get one from either a mach 1 or a cobra believe me you will like it more and it and it will cost you less in the long run
FS: Mach 1 OEM Wheels 3K miles with NEW Nitto 555's 275/40/17's PM me http://www.moddedmustangs.com/forums...555s-rear.html |
01 mustang gt
13.98@100
+1 on 4v swap
the 4v motors are becoming increasingly easier to find and there is more potential in them. not to mention that there is a boat load of info on the swap since its been done. but if its somethin that your set on doin then alot of its going to be new stuff, there wont be much info... just as a heads up
destroy in the turns, then obliterate on the straightaway 01 GT 4.6/20 over cold air intake/70 mm throttle body mac longtube headers/custome H pipe/moroso spiral mufflers to side exhaust computer tune race seats / 5 point harness
the swap is not hard to do at all. you can use your ecm from your car with the new engine. everything will bolt up nice. there is a kit available for the swap you want to dod for like $300
1998 GT suckaaa
4 tickets @ 1 stop
Military Crew
Completely stock... I promise. ![]() |
Threads Similar to: 4.6 ford mustang gt motor swap!!!
| 2006-2010 Ford Mustang GT 18in OEM bullit rims on 94-98 Ford Mustang ¨sn95¨ question | 96cobra201 | V6 Mustangs | 16 | May 13th, 2010 03:19 AM |
| Formula Drift 2010 Falken Ford Mustang Wrecked/Repaired at Las Vegas Motor Speedway | K&N Filters | K & N Filters | 0 | September 22nd, 2009 05:23 PM |
| 29th Annual Mustang & All Ford Car Show & Swap Meet in Indianapolis | j21moss | Midwest | 39 | August 13th, 2008 10:17 PM |
| 5.0 Mustang Motor Swap Badass | 5.slow | 5.0 Mustangs | 1 | November 8th, 2006 10:25 PM |
