04 Mach1, 89 Modded GT
Fuel injectors lbs question
the heavier the lbs of the fuel injector the more fuel is atomized and injected into the intake manifold correct?
KB'd GT
Nope, the "lbs" is lbs of fuel per hour, not pressure.
10.67
2000 GT 60' 1.42 1/4 10.49 mph 129.8 |
Moderator
2003 Grand Cherokee
Isn't that what he said? More lbs/hr of fuel = "more fuel is atomized and injected into the intake manifold"
KB'd GT
No. The ECU will only inject the fuel needed. The lbs/hr rating is for max flow. Using injectors rated for a higher lbs/hr than needed will result with LESS atomization due to the larger bore.
Moderator
2003 Grand Cherokee
Hmmm, you learn something new every day.
ok my next question, the lbs of fuel per hour is actually the amount of fuel expended within an hour?? for example, if i have 30 lbs injectors, i am actually expending 30 lbs of fuel per hour of driving? and is that calculated at an idle? or at a set standard rpm? or what?
#8 | ||
KB'd GT
Threads Similar to: Fuel injectors lbs question
| SVT fuel pump, fuel injectors | Kennhyy3 | V6 Mustangs | 2 | December 19th, 2008 06:08 AM |
| 24 lbs injectors and a fuel pump... | b-on-b 5.0 | 5.0 Mustangs | 7 | October 21st, 2008 11:24 AM |
| fuel injectors question | sixpack | 5.0 Mustangs | 1 | May 21st, 2008 10:46 PM |
| Quick question about fuel injectors | MIGHTYJO3YOUNG | 5.0 Mustangs | 21 | February 11th, 2008 12:07 PM |
| Fuel Injectors/fuel pressure | 00silvergt | 99-04 | 4 | August 2nd, 2007 10:54 AM |
