Power shifiting, granny shifiting, double clutching?
Old February 17th, 2007, 01:26 AM   #1
dmachine22's Avatar
1998 Z28
dmachine22 is on a distinguished road
What the hell is the difference and which one would be best for racing at the track my first manual was a 5.0 5spd 1993 and I learned pretty easy and now i have a 99 5spd gt and this is over the span of 8 months of expirence so i'm not real familiar with those terms I know what granny shifiting is and I know it saves the transmission so i heard better than the other two but still with the tracks opening here in about a month and this will be my first time at a track I can launch the car 80% of the time right, than from there I just quickly switch thru gears but would power shifitng or double clutching be a better option?
Unknown
Old February 17th, 2007, 05:52 AM   #2
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
97Cobra will become famous soon enough
power shifting is not even taking your foot off the gas just hittin the clutch n shifting real quick.....hard on trannys! granny clutching is taking you foot all the way off the gas pushing the clutch in n shifting......
Modifications and pics in my Garage...
Reps Appreciated!
Old February 17th, 2007, 06:36 AM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
double clutching is pretty much what it says it is. i powershift and as for times will be faster as long as you can plant the power. it will be hard on the trans (i am on trans #3) but its all up to you.
Old February 17th, 2007, 08:16 AM   #4
dmachine22's Avatar
1998 Z28
Thanks for the tip I only plan on racing at the track so hopefully it wont mess up my tranny 2 bad
Unknown
Old February 17th, 2007, 03:16 PM   #5
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
quit watching fast and the furious there homie, powershifting is like an artform and its hard to do it right, doublt clutching is stupid, i say just try to get your car down the track in one piece and gain experience and everything will start coming into place. The problem with breaking trannys when powershifting is all about clutch dissengagment, a big part of that is the adjustable cutch cable, quandrant. The stock one actually flexs at the firewall so your not getting full cable release and the clutch stays partially engaged while trying to shift. Call promotion powertrain and talk to Walt and order on of there quadrant and cables. Theirs are used in cars running low 9's with a 5 speed. I just ordered it plus all of there stuff for inside my T-45 to handle 500hp and being able to shift at 7000rpms
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old February 17th, 2007, 03:45 PM   #6
dmachine22's Avatar
1998 Z28
Actually I got this from a subaru forum and I always wandered about the difference, i heard double clutching is for semis n e way but I was more wandering if I should power shift or regular shift?
Unknown
Old February 18th, 2007, 09:54 AM   #7
Casper98GT's Avatar
white youre the MAN. I saw this and almost died laughing.
The entire movie was a joke and it should have NEVER been made, even if it had Mustangs in it and nothign else. Nothing was technically correct.
Why would you need to double clutch when youre racing unless you have some old piece of crap transmission or youre syncros were bad.
Power shifting you can do, but like everyone else said its hard on youre tranny and driveshaft and rear end. I do it 2nd, 3rd, and 4th. But never from 1st to 2nd because i would spin sideways and crash. Unless im running my DR's.
And i have my stock tranny still even when PS's on DR's.
Goodluck!
91 LX, 5spd.
Ex:Toyota/Ford tech
Old February 19th, 2007, 02:33 AM   #8
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Double clutching is only for transmissions without syncros. As long as you can rpm match (yes, both up and down), you're fine.
I don't suggest it, but a good way to get a feel for what rpms you need for rpm matching is to try hotsticking the tranny (shifting w/out using the clutch at all). I suggest trying this first on the upshift. Just take first out a little higher than you usually do, then, just pull back on your shift lever, pressing against the gate for 2nd. When the rpms are right, it should drop into gear. A little practice, and you should start being able to do it up and down. Again, not something I suggest you do, but it is an option.
O o
/¯/______________________
\_\
Old February 19th, 2007, 07:30 AM   #9
TheUNZippee!'s Avatar
Double clutching is done in trannies without synchros as revdex says.Such as in a tractor trailer, which I drive. It means you step on the clutch twice, and is not for racing. As you step on the clutch the first time, you are moving the shifter out of it's present gear. Then you release the clutch. Then you step on it again, moving the shifter into the next gear as you do so.
Power shifting is done by keeping the accelerator floored, and without taking your foot off it, you bang the clutch to the floor while you are simultaneously moving the shifter, so that you are making the gear change at the instant your clutch pedal is hitting the floor.You don't hold the clutch pedal down for even an instant, you just bang it down with your foot and release while you move the shifter at the same time.
It takes practice, and the key here is to WATCH your rpm's, especially if you don't have a rev limiter.The whole idea is that the shift is accomplished far faster, which means when you engage the next gear, your engine will not have dropped as much rpm, meaning you are higher up in the powerband where you have more horse,which equals better acceleration.
It's harder on equipment, but if you are drag racing, you aren't using your car for longevity.
Originally Posted by My Wife
Old February 19th, 2007, 08:55 AM   #10
csredfire07 is on a distinguished road
Just courious, what rig in this day in age needs to be double clutched? I have both Eaton 8LL and 15 spd and I only need the clutch for going into firest and reverse. Double clutching is from the early 80's and before. Remember quad boxes?
Old February 19th, 2007, 09:50 AM   #11
dmachine22's Avatar
1998 Z28
Yeah thanks i've been hearing alot that it does improve acceleration but is also hard on your tranny as well and you have 2 get used to it so practice makes perfect im just trying to get the best out of my 1/4 mile as possible when I head 2 the track thanx!
Unknown
Old February 19th, 2007, 10:37 AM   #12
matrixpuba is on a distinguished road
Send a message via AIM to matrixpuba Send a message via MSN to matrixpuba Send a message via Yahoo to matrixpuba
remember liftin aint shiftin lol
Old February 19th, 2007, 01:47 PM   #13
+1 matrix
Yeah like I said dmachine, it can be hard on equipment, but dragging your car is harder on everything involved, so whatcha gonna do. Breaking shit is part of serious racing.
Good luck at the track & have fun learning!
Old February 20th, 2007, 02:59 PM   #14
Which means no serious racing in your daily driver! (or in my case, your girlfriend's daily driver )
O o
\_\
Old February 20th, 2007, 03:05 PM   #15
dmachine22's Avatar
1998 Z28
I tried it yesterday going from first to second and it scared the hell out of me lol because I did not do it fast enough and the rpm gauge jumped and then I landed in to secound and the back end went sideways on me it will take a little practie but ill get it I like the quicker power it gives by not letting the rpms drop so much I feel like i'm learning how to drive a manual again!lol
Unknown
Old February 20th, 2007, 06:32 PM   #16
Trick Tuners's Avatar
KB'd GT
Practice at lower rpms before doing WOT redline power shifts for your first time. Maybe at 3500 instead till you get it down, but be careful not to break anything!
Old February 20th, 2007, 07:09 PM   #17
dmachine22's Avatar
1998 Z28
yeah I know I should of done that my first time but actaully it just goes right into gear without any hesitation at all when I power shifted I figured I would have to jerk it in there but my clucth is only 2 1/2 months old so it went in real easy thanx for the tip!
Unknown
Old February 21st, 2007, 03:15 AM   #18
Glad you're having fun, dmachine. It's not so hard to pick up with a little practice. Just remember once you get good at it, to not get complacent & always focus %100, cause that's usually when you start breaking shit. Not that I've ever done that. *cough*
p.s. What your gf doesn't know won't hurt you. lol
Old February 21st, 2007, 10:41 AM   #19
dmachine22's Avatar
1998 Z28
lol
Unknown
Threads Similar to: Power shifiting, granny shifiting, double clutching?
Get it Granny! 03 R Code Videos 5 May 9th, 2007 08:17 PM
Is double clutching still relevant? torquecars Racer's Corner 79 April 20th, 2007 03:57 PM
clutching times inthered03 99-04 2 January 29th, 2007 12:40 AM
Granny Machine Gun DanishStallion The Clubhouse 0 October 11th, 2006 10:11 PM
Gammer Granny JRuckas The Clubhouse 15 August 31st, 2006 08:30 PM
