2004 Cobra Suspension
Old December 3rd, 2009, 01:20 AM   #1
Look Ma! My First Post!
badbrad34 is on a distinguished road
Okay. I have a 2004 Cobra with an Eibach lowering kit and QA1 adjustable shocks. My car also has an 8.8 straight axle in the rear. Right now it has a drag set up, which doesn't have a very good ride quality. I'm looking for a suspension kit/setup that has great ride quality as well as performance. If anyone has any ideas, I certainly would like the input. Money is not an option, so I'm looking for the best suspension out there.
Old December 3rd, 2009, 02:17 AM   #2
06dkkiser's Avatar
2006 Mustang 4.0
06dkkiser is on a distinguished road
I would get Coil Overs on all 4's
Your woman is the one who allowed the other man's penis to repeatedly cram her juice box, over, and over, and over, furiously pounding her muff until her soft tender folds orgasm all over his ever thrusting, pounding, baseball bat of love.
Old December 3rd, 2009, 06:01 PM   #3
ModMustang97GT's Avatar
1997 Mustang GT
Faster than an s4
ModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura about
Do not get coil overs in the rear. You can't get a soft enough spring for the rear coil overs to keep the ride comfortable. MM states flat out that you should not get rear coil overs if you worried about ride quality. For drag racing and ride quality you will want a not so stiff spring in the rear. Your eibach springs are plenty. I would get coil overs for the front and then get a set of either the matching eibach schocks to your springs, or go with some adjustables.
The Tokico illuminas are the best drag adjustable out there. You can set them great for the track, then dial em back a bit for the drive home. Also, do you have subframe connectors? I would recommend a good set and front coil overs with a 250 lb/inch spring, something pretty soft. It will still handle better than your stock springs because they are coil overs, and they will work together to give you a MUCH smoother ride.
The ride quality is really directly from the spring location on the arms. Your springs are around 650-700 lbs/in but because of where they are located. You feel the harshness of a 700 lb spring in the ride, but you only get a 200-300 lbs of force at the wheels. So you get a harsh ride with poor wheel rates. Coil overs fix that. 300 lbs on the body (less stiff than the stock springs for harshness) and the same 300 lbs on the wheels.
Aztec Gold 97GT.
MM CC Plates, Panhard Bar, SFC's & Tower Brace
Eibach Sway Bars
H&R Race Springs/Bilstein Shocks
MAC CAI, LT's, Catted H and Pro-Dumps
KB Boost-a-Spark
04' PI Motor
Author of The Official Suspension Guide
Old December 3rd, 2009, 06:05 PM   #4
2009 ROTY
AzSonicSnake's Avatar
2003 SVT Cobra
11.07@127
AzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud of
Send a message via AIM to AzSonicSnake Send a message via MSN to AzSonicSnake
^^^ definetly some damn good advice there. i'd take notes!
MM Cobra Club #25 My Autolog Profile
Old December 5th, 2009, 07:15 PM   #5
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
Best suspension >< ride quality
You are going to need to make a decision on this one. You want ride quality, stick with softer springs, lighter shocks/struts and keep your suspension OEM. You want the best out there....? Go Griggs or go home
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old December 6th, 2009, 03:20 PM   #6
1997 Mustang GT
Faster than an s4
He;s looking straight line though. For drag racing, you can still have some semblance of ride quality with decent performance. It sounds like you are not the trailer queen type racer, so you should be able to get away with an upgraded set of lower control arms, springs and shocks. And some front coil overs will make the front lighter and have better performance on and off the track.
Aztec Gold 97GT.
Eibach Sway Bars
KB Boost-a-Spark
04' PI Motor
Threads Similar to: 2004 Cobra Suspension
looking for 2003 or 2004 cobra droppedbass87 99-04 10 January 9th, 2008 04:57 PM
Fox suspension on a 2004 V6 Ole Yeller General Tech 0 June 10th, 2007 03:09 PM
2004 Cobra thecloneranger 99-04 15 March 12th, 2007 10:40 PM
