Stock fox rear end
Old February 20th, 2007, 08:25 PM   #1
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
Stock fox rear end
I am just wanting to know what kind of diff.s are in the stock fox body gts...... the 1990 specifically. I just bought my stang and love driving it and spinning tires and what not. I've notcied for the most part it will possi up when spinning unless i power brake it. It does spin both tires once i left off the break and take off. Also sometimes it only spinns on tires if i cut to the right but if i ever cut to the left and punch it i get sidewayz.
anyway im just wonderin if i should have a limited slip or if the car is so light and thats the reason that it will get sidewayz fairly easy.
and yes i did search this topic to find the answer because im sure its been discussed but i couldnt find a real answer
thanx for the help in advance.
Old February 21st, 2007, 02:42 PM   #2
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
V8 mustangs from the mid-eighties on have had an 8.8" rear end with the Ford Traction-Lok (sp?) clutch-style limited slip. From what I understand it's a mediocre LSD when new, and it goes to crap after a couple years of normal use. I know you can buy rebuild kits from FRPP, or you can replace it with a better limited slip unit (like an Auburn, Detroit, etc etc).
O o
/¯/______________________
\_\
Buy my Bronco, special deal for MM folks
Old February 22nd, 2007, 07:26 PM   #3
1990 Mustang GT
thanx man that answered my question
Threads Similar to: Stock fox rear end
4:10's in stock rear 95wip 5.0 Mustangs 8 July 1st, 2007 12:57 AM
stock rear end capable of? Santaniello3blkstang V6 Mustangs 13 June 15th, 2007 11:21 AM
stock rear axle 69_5.0_stang Classic Mustangs 5 May 3rd, 2007 06:59 AM
yay! my GT doesn't like 5k rmp launches on a stock rear end! HMUSN Modular Mustangs 26 December 16th, 2006 09:16 PM
Stock Rear End On 03 GT? Gtwrestler 99-04 2 October 26th, 2006 07:22 PM
