Discussing diff noise in the Modular Mustangs Forum. we have a 1999 4.6 GT and it has a noise in the rear ...
Old February 21st, 2007, 05:29 PM   #1
diff noise
we have a 1999 4.6 GT and it has a noise in the rear axle ,can anyone please help with info on wheel bearing replacement DIY .many thanks.PS we are in australia so not many techs. thanks Amber
Old February 23rd, 2007, 01:36 AM   #2
97_4.6L_Stang's Avatar
what kind of noise.
97 Mustang GT, MAC CAI, Underdrive Pulleys, Flowmaster Exhaust, BBK Offroad H-Pipe, 3:73 Gear, Autologic Chip, B&M Short Throw Shifter, Centerforce Clutch, Msd, Eibach Sportline Springs
Old February 24th, 2007, 04:19 PM   #3
it sounds like a crrrrrrrrrin the wheel bearing or carrier bearing at wheel speed.
Old February 27th, 2007, 12:46 PM   #4
If it is a wheel bearing, it's not hard to change. I just did mine this past week.
You'll need:
a slide hammer ( to knock out the bearings)
correct size socket used with heavy hammer to install the new bearings back in (I used 1 5/8)
new seals
new cover gasket
sealant
new gear oil plus a friction modifier
a shop manuel would help too
Old February 27th, 2007, 03:39 PM   #5
Casper98GT's Avatar
Well, remove the wheel.
remove the caliper and rotor...remove the ABS sensor first
remove rear diff cover and drain fluids..remove c-clips and remove axles
use seal removerr and remove seal then use slide hammer with attachment for wheel bearings and remove bearing. Intsall in reverse
White99stang-
Damn i miss the good ole days, you know in 2005 when the site first started and everyone wasn't getting butt hurt over every little thing
Ford/Toyota tech.
93 LX, H/C/I + Vortech
Threads Similar to: diff noise
Noise in rear diff ?? BoostHard1210 99-04 3 July 12th, 2007 11:00 AM
How much diff will it get you? scxc15 V6 Mustangs 8 May 20th, 2007 02:38 AM
think its about that time 2 get a diff car... justinsstang The Clubhouse 25 May 10th, 2007 06:14 PM
Rear Diff Noise jdm2007 2005+ 8 April 29th, 2007 10:20 AM
2005 auto mustang vibration noise/ rumbling noise ozan169 2005+ 4 March 13th, 2007 05:31 PM
