Timing Cover Confusion
Old December 11th, 2009, 01:38 AM   #1
281SLEEPER2v's Avatar
2000 MUSTANG GT
13.03 @ 103
281SLEEPER2v is on a distinguished road
my mustang is a 2000, long water pump, windsor motor..Ok so when i installed my cams and was putting my timing cover back on, it snapped at the bottom. there was a huge crack. so i found this guy that had a motor out of a 2000GT. i went to get the timing cover off of it. the pulleys on it were different. it went with the short water pump. and the belt tensioner was different. anyway the timing cover bolted right up to my motor, i had to swap water pumps as well. when i went to go get a belt, i asked for a 2004 belt since the timing cover used the short water pump(that was my guess). when i go to put the belt, the belt is waaaaaay too big. i did my research and it turns out the belt tensioner i put on now is from an early 4.6(96-98)meaning that the timing cover is also from an early 4.6
here is a pic of the belt tensioner on my car now..
My car runs fine but it only does one annoying thing. every time i brake as i decelerate with the car in neutral the cars rpm's just sputter and the the car dies....when the car is at a dead stop and i step on the brakes real hard the rpm's drop...ive gotten used to it, but i would really like to solve this problem. at first i thought it was cause of the cams but i realized it does it only when i step on the brakes. im wondering if it does this because its a different pulley set up or could there be another reason why its doing it...any suggestions and help will be greatly appreciated.
VALLEY STANG
2v+Cams+Nitrous
stock longblock till she blows
Threads Similar to: Timing Cover Confusion
timing cover ? Graytex 96-98 3 July 25th, 2009 03:29 AM
timing cover Imran 99-04 69 May 7th, 2009 09:48 PM
Help Please Timing Cover!!!! Stang281GT 99-04 12 July 9th, 2008 05:53 PM
timing cover Black Five 0h 5.0 Mustangs 3 April 17th, 2008 09:52 AM
Timing Cover 68 dlxcoupe 96-98 3 March 31st, 2008 01:59 AM
