Discussing Trashed 99 Cobra Block in the Modular Mustangs Forum. Ok guys after searching for a couple of hours I still can't find a ...
Old February 23rd, 2007, 01:22 PM   #1
Ok guys after searching for a couple of hours I still can't find a clear answer. I have a 99 cobra that decided to spit out two rods through the block. My ? is since my heads are fine what motor is a direct replacement? I have heard Mark 8 motor, expedition, police 4.6, I will be using my heads and intake.
Old February 23rd, 2007, 02:13 PM   #2
1998 SVT Cobra
I would think that any 4v 4.6L block would work, terminator blocks are going to be iron, I'm guessing you want to stay with aluminum. I know that the later lincolns ran the 32v, I didn't know that the expedition ran a 32v, I thought it was the regular 2v motor. The navigator has the 5.4, but I believe the Aviator has the 4.6, Any Cobra from 96-01 should have that block (R models excepted, of course).
Or you could take the chance to get a stroker in there, since you're replacing your bottom end anyway... get one of the 5.0 kits... hehehheh.
The Sacred Chao says "MU"
'96 Bronco XLT
'98 Cobra
'89 Camry AllTrac
Old February 23rd, 2007, 03:21 PM   #3
drgnracin72's Avatar
2000 mustang GT
11.79@125
if i had a cobra R, i'd take out the vents and put little miniature fish tanks in their places and fill them with sea monkeys
McCain/Palin 08
Old February 23rd, 2007, 03:57 PM   #4
HURRAY low RPM's!! But damn it be sweet.!!
Official MM Zeppelineers. Crew member #3
http://www.moddedmustangs.com/forums...anner1_178.jpg
Old February 27th, 2007, 08:14 PM   #5
Anybody else? Can I just use a 00-03 Gt shortblock? Any difference between cranks,rods, pistons, compression?
Old February 27th, 2007, 09:16 PM   #6
MustangMatt96GT's Avatar
12.91@105.29 @ 5800 FT
Well the GT block is single over head cam, so it will not work. I would suggest a 5.0 stroker aswell, but if money is an issue, just rebuild with another block mention above.
Old February 28th, 2007, 04:07 AM   #7
actually the sohc block could work if you feel like spending the time and money to have the machine work done to retrofit the dohc heads. but then the real wortk will be to swap the front part of the motor. i thought i read where someone tried this on another forum.
the mark8 block would be you best bet i think. when they are properly buuilt the aluminum block can handle 1000hp the mark8 block were made in italy. place called teksid i believe. very goo d block from what i have read.
as long as its a dohc motor it will work.why not for the 5.4 dohc!!!
Threads Similar to: Trashed 99 Cobra Block
Trashed the T-45... now what are your suggestions? NEW STUFF Slowbra_12 96-98 3 October 4th, 2007 01:14 AM
Unbelievable - Body Kit Is Trashed fallstar01 Visual 19 March 25th, 2007 03:40 PM
Help! New Tires Trashed! Skullman Suspension 12 January 17th, 2007 12:02 AM
Stock Cobra Block and GT Block the same?? bbrewer03 96-98 2 August 26th, 2006 01:31 PM
T5 Trashed 1gunner23 5.0 Mustangs 10 May 1st, 2006 12:48 AM
