Cars Overheating? I think?
Old January 21st, 2010, 09:49 AM   #1
'97'Cobra's Avatar
1997 Mustang Cobra
8.65@84mph
'97'Cobra has a spectacular aura about'97'Cobra has a spectacular aura about'97'Cobra has a spectacular aura about
So for the last couple of days my temp. guage is showing me that the car is getting alittle warm even on the highway but not to bad.
A day later my alternator was going bad and giving low volts so i replaced it.
Runs great now but this morning when i was driving to work the temp guage wasnt reading at all. Around 10 min later it spiked for a couple of min then went back to normal but got real hot once the car warmed up.
If i sit at a light the guage will spike until the car starts moving. When i got to work i popped the hood to see if the fan was coming on and it wasnt but i didnt let it sit long because the guage was tapped out.
So does this sound like a guage or a fan or...... Im broke do to the altinator so hopefully i dont need a new fan... HELP
i usually wave first, but if the guy is sexy and i'm drunk, i might lift up my shirt and flash him as well.
MM Cobra Club Member #61
Old January 21st, 2010, 10:24 AM   #2
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
Do you have a tuner? I would check current data and check the ect sensor then pressure check the system. I am guessing you have air in the system and a leak somewhere. There is a bleeder screw in the top of the coolant crossover you can use to remove the air.
TT Build in progress.......
Old January 21st, 2010, 11:50 AM   #3
'97'Cobra's Avatar
1997 Mustang Cobra
8.65@84mph
To bleed it i just crack it open and let the car idle?
Old January 21st, 2010, 12:38 PM   #4
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
yeah do that and monitor it. let the car get to normal OT and then check for air bubbles, squeeze the hoses to make sure all the bubbles escape, and top off as needed. also turn your heater to full blast. If your fans arent kicking on it may be because your sensor is bad and not putting out the right output to kick the fans on. If it turns out your sensor is bad ive got an old one that was working just fine only reason why i pulled it out is cause my when i ordered a new coolant crossover tube it already came with a new one.
BUILD 2 IN PROGRESS
Old January 21st, 2010, 12:58 PM   #5
'97'Cobra's Avatar
1997 Mustang Cobra
8.65@84mph
sweet man, hope my fan isnt messed up. Im almost certain it has air in it i hope thats the only problem
Old January 21st, 2010, 01:08 PM   #6
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
yeah bro, its not hard to bleed the system of air at all... just time consuming sometimes if there is alot in there.
BUILD 2 IN PROGRESS
Threads Similar to: Cars Overheating? I think?
help overheating!!! Traidmarx 5.0 Mustangs 20 June 9th, 2009 08:47 PM
Muscle Cars Vs. Compact Cars?? I Need Help Deciding.. Hunt_chevs The Clubhouse 12 June 3rd, 2009 09:34 PM
overheating TKOTLARZ 94-95 24 June 21st, 2008 01:48 PM
96 Overheating 6 banger stang V6 Mustangs 2 October 30th, 2006 01:58 AM
Overheating! But Why? Unreal V6 Mustangs 1 September 6th, 2006 05:55 PM
