Discussing Installation questions in the Modular Mustangs Forum. Ok so im about to do my pi headswap this weekend (im using the parkway ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Installation questionsSecond question: I have asked a few people this and havn't really gotten a good answer. Where exactly do i put the RTV sealent, and how much do i use and how do i apply it? ![]() And any other advice for doing this would be appreciated as well! I dont want to screw my car up haha. Any help with this is greatly appreciated!!!!!! Thanks LaserRed96GT |
#2 | |
Second q" first, you dont need RTV if you do the entire headswap. Thats for the PI intake swap.
first q', When you get the PI intake look at it with the alum facing down...look to the right hand part near the thermostat and you will see a shiney spot about the size of a quarter. Thats where you drill and tap. Its pipe thread by the way. So be careful. I suggest to people taking the sensor and intake and having a machine shop drill and tap. Much easier.
White99stang-
93 LX, H/C/I + Vortech |
ok so u only really need to use rtv when u do the pi intake swap on non pi heads?
Also where did u find pipe taps cause all i can find are machine taps : ( also for pipe taps is the process of tapping it any differnt then with machine taps? Like what size hole would i drill for it if it is pipe thread? Do i use a 3/8ths drill bit or do i have to use like a tapperd drill bit?
Thanks again |
granger, mc master carr, fastenall, or a plumber's supply house will have them.
a local machine shop should have them also
97 gts 1 of 1135 in aztec gold option 248a pi swapped 75 mm tb and plenum 80 mm maf 24 lb injectors frp shorties flowtec o/r h hooker areos w/ dumps motive gear 3.90 sct tuned 247 rwhp 303 rwtq 88 t-top lx 68 coupe project. was my grandads |
2003 GT
Street Fast 16.9@76MPH
You do need to use the rtv.
1. at the bottom corner where the timing cover, oil pan, and block meet. 2. at the joint where the heads meet the block before installing the timing cover. 3. where the heads meet the timing cover underneath the valve covers. 4. in the keyway slot on the harmonic balancer. |
#7 | |
I have the link at my house for the exact tap cost me like 12 bucks
White99stang-
Threads Similar to: Installation questions
| LED Installation | Devthedevastator | Visual | 1 | November 5th, 2007 07:15 PM |
| How much is installation? | NeoAnderson48 | V6 Mustangs | 14 | September 3rd, 2007 05:26 PM |
| FS: 4.10s with installation kit | Aliate X | For Sale | 62 | May 10th, 2007 02:49 AM |
| Gear Installation | Jeff99gt | 99-04 | 9 | March 10th, 2007 12:22 AM |
| $Installation price$ | dblindberg | 2005+ | 8 | February 12th, 2007 09:46 PM |
