05+ seats in a 97
Old February 9th, 2010, 05:54 AM   #1
mystk96's Avatar
2005 trd tacoma sport
mystk96 will become famous soon enough
Wink
05+ seats in a 97
so here recently i got rid of the camaro ss i purchased but i got lucky and found a pi swapped 97 gt with cams for a decent price but the seats suck so i was wondering two things first will the 05 seats bolt into a sn95 and do they hold you like the 03 04 mach 1 seats
thanks in advance
Old February 9th, 2010, 11:07 AM   #2
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.99 @ 113.9mph
sharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to behold
iTrader: 9 reviews
I had to make some adapter brackets when i put my racing seats in. You may have to do the same but it works
374rwhp 456rwtq @ 8psi
Old February 9th, 2010, 09:04 PM   #3
99 mustang GT
ForestGRN_Ghost will become famous soon enough
Send a message via MSN to ForestGRN_Ghost
i would also like to know this...
sharkbait was your brakets in anyway hard to make or simple modification ?
Old February 9th, 2010, 10:03 PM   #4
97Dustang's Avatar
97 GT and 03 Cobra
12.75@105
97Dustang will become famous soon enough
sharkbait, do you have racing seats or 05 mustang seats?
2003 COBRA FOR SALE PM FOR DETAILS
Old February 9th, 2010, 10:37 PM   #5
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.99 @ 113.9mph
iTrader: 9 reviews
Just racing seats. But the way i did it could be duplicated pretty easily for other applications.
Pretty much heres a quick over view--
I got some ebay racing seats (nicer ones) and they didnt come with brackets. Just some semi fuctional sliders. I wasnt pleased. So what I did was I took some 1.5" x .25" steel and bolted that down to the bottom of the seat. Then I did some drilling and marking and bolted that down to the driver side power seat thing. I had to drill new holes into the driver side slider/bracket to make them match up with the cross peices i made from the steel. So pretty much bolt the steel to the seat. Then mark and drill new holes into the bracket/slider and the steel.
Now for the passenger seat I did something a bit simpler. Get a large flat peice of steal. A square, probobly best to keep it about 1/4" thick. Bolt that entire sheet down to the bottom of the seat into the stock holes. Then copy over the holes of were the stock slider/brackets holes are and mark and drill those to the piece of steel. Pretty much so the bracket/slider bolt to the peice of steel and the steel bolts to the seat. If you worried about some weight savings you can drill out the center of the seat.
For the passenger seat with the slider. Do not drill new holes into the top if the slider. Cause theres a bearing in there and it will get stuck on any new hardware. Use the stock holes.
For the driver side i had to cut out the power seat moving thing out of the driver seat and i just let is sit under the seat (i dont normally change my seat).
Any questions?
Old February 9th, 2010, 10:43 PM   #6
97Dustang's Avatar
97 GT and 03 Cobra
12.75@105
hmmm i guess it works ... not exactly sure how safe it sounds but watever floats your boat. i dont know if 05 seats will fit or not, there is alot to consider, i highly doubt that they will bolt right in, and if you have custom brackets made or something like what sharkbait did you need to make sure that the seat physically fits into the car they might be a bit wider than ours. if i were you i would browse craigslist, the for sale section on forums, and junkyards and look for some seats from our years, much less headache
Old February 9th, 2010, 10:46 PM   #7
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.99 @ 113.9mph
iTrader: 9 reviews
Mine were a xmass gift so they needed to work.
Again only use STEEL for this and good hardware. Im going back and welding some of the stuff when I get out of here. But it worked for me. Il be installing my harnesses soon! im so excited!
Old February 9th, 2010, 11:00 PM   #8
97Dustang's Avatar
97 GT and 03 Cobra
12.75@105
what are you mounting your harnesses to?
Old February 9th, 2010, 11:14 PM   #9
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.99 @ 113.9mph
iTrader: 9 reviews
Well there 5 point harnesses.
So ofcourse im getting a harness bar for the back. Those back 2 straps go over the bar and are mounting to the back 2 bolts of where the bracket meets the floor. The 2 lap straps are going into the stock mounting points. Then for the middle one im not sure yet. I might copy steeda's desgin and weld together a bracket that goes between the 2 front bolts so the middle one stays in the middle.
Iv done some research
Old February 9th, 2010, 11:17 PM   #10
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.99 @ 113.9mph
iTrader: 9 reviews
These--
Front Submarine Race Belt Mounting Bracket - 79-04 Ford Mustang
Old February 9th, 2010, 11:40 PM   #11
97Dustang's Avatar
97 GT and 03 Cobra
12.75@105
ok i was just wondering cuz i had the guy weld all those tabs to my cage and floor pan and i was just wondering what your plan was
Old February 10th, 2010, 12:02 AM   #12
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.99 @ 113.9mph
iTrader: 9 reviews
Yea, I know my car has no need for a harness. But there fun. Which really is all that matters. Also I feel safer.
Old February 10th, 2010, 12:15 AM   #13
97Dustang's Avatar
97 GT and 03 Cobra
12.75@105
yep, its your car do what you want with it
Old February 10th, 2010, 12:34 AM   #14
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.99 @ 113.9mph
iTrader: 9 reviews
Idk its one of those things from the start that I wanted.
My freind has a v6 camaro. Its not fast, but hes got big drag radials coming out the back. It looks sick, might be slow but looks sick.
My car might not be the fastest in the forum, but if i get in every time and love life. Thats all that matters. Sometimes people in here get confused and forget that its not always about being the fastest and most correct. Your supposed to have fun.
Old February 10th, 2010, 12:47 AM   #15
97Dustang's Avatar
97 GT and 03 Cobra
12.75@105
+1 to that
Old February 10th, 2010, 12:52 AM   #16
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.99 @ 113.9mph
iTrader: 9 reviews
So any new mods to your ride 97? any plans?
Old February 11th, 2010, 10:30 AM   #17
97Dustang's Avatar
97 GT and 03 Cobra
12.75@105
just got it back with actually, i got a 10 point cage in it, now im painting the cage, then im putting the interior back in and i got a nitrous kit that i'll put on once the interior is back in
What are your plans after the harnesses?
Threads Similar to: 05+ seats in a 97
Convertible seats vs. Coupe seats.... BakerFX4 99-04 13 August 1st, 2009 03:17 PM
Cleaning Seats and Under Seats crappy_head 99-04 9 August 21st, 2008 10:04 PM
Seats notfastenuff 5.0 Mustangs 2 November 25th, 2007 10:57 AM
