smokes every now and then
Old March 14th, 2010, 09:10 PM   #1
2002 gt
jbwildboy is on a distinguished road
Every now and then but not every time i run my car it will smoke for a bit and its pretty white then i run it for awhile and it clears up
Imports are like tampons every pussy needs one
07 f150 lariat 4x4 cai, throttle body spacer, flowmaster,edge programmer DD
79 f150 built 460 10 in lift on 38s
Old March 14th, 2010, 09:16 PM   #2
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
Welcome to the forums. What are your mods?
Old March 14th, 2010, 09:32 PM   #3
2002 gt
The car is an 02 gt the motor is a 99 cobra aluminum block, forged crank, h-beam rods, mahle forged 8.5:1 pistons, 99 cobra upper and lower intake.Has a direct port nitrous fogger, 04 cobra 4v heads and cams, tremec t-56 6spd tranny with a pro 5.0 shifter, upr off road x pipe with a heart throb cat back with 3 " tips. Suspension is full upr. Upr k member and tubular a-arms, adjustable front coil overs with a bumpsteer kit. full length upr subframe connectors welded in, rear double adjustable uppers and lower control arms, drop coils, upr spherical bushings, 4.10 gears with a upr rear girtle. red top optima battery swapped to the trunk along with the 15lb nitrous bottle. custom tuned with sct excal 3 tuner at total performance solutions.
Old March 14th, 2010, 09:34 PM   #4
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
figured it had an x pipe..
Mine smoked for a lil on start up too.
Old March 17th, 2010, 05:08 PM   #5
ckthecerealkiller is on a distinguished road
What does the smoke smell like?
Old March 17th, 2010, 10:49 PM   #6
2002 gt
it kind of smells like gas sometimes my service engine lights comes on now and then and the code is that it is running rich but i thought when it runs rich it is darker gray smoke this one is more white sometimes if im just driving normal then down shift and stand on it it will shoot a puff of smoke then it will clear up maybe jus some unburned fuel
Old March 17th, 2010, 10:56 PM   #7
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
with that compression ration throw a blower on there!
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old March 17th, 2010, 10:58 PM   #8
2002 gt
ya thats what its built for jus threw nitrous on there until the money comes for a turbo
Old March 25th, 2010, 01:59 PM   #9
Dark gray is gas. Might want to get a dyno but if you are planning on FI you should get one anyway.
Threads Similar to: smokes every now and then
My pony Smokes sometimes noyz25 5.0 Mustangs 7 July 27th, 2009 05:42 PM
Who smokes? Blk04Snake The Clubhouse 39 July 25th, 2009 10:56 PM
holey smokes whitemustang02 The Clubhouse 1 June 13th, 2008 10:13 PM
Mustang Smokes Sometimes sean97gt 96-98 1 November 2nd, 2006 02:23 AM
Smokes once in a while phazedragon General Tech 5 August 4th, 2006 10:08 AM
