New clutch slipping? - Forums at Modded Mustangs
post #1 of 8 Old March 24th, 2010, 12:56 AM Thread Starter
About a year ago a friend and I put a new clutch in my 2000 GT... a Ram HDX to be specific... and a factory re manufactured flywheel. Now the Ram HDX is supposed to be good to 450 hp... my Mustang has intake, exhaust, programmer.. so it's sitting slightly over stock numbers.. nothing ridiculous at all.. the other day i romped on it in 1st gear (which normally equates to going sideways) and nothing.. no spinnage.. then Saturday morning i ran it up hard through 1st, 2nd, and 3rd to about 85ish and shut it down, and came to a quick stop to make my turn at which time i smelled burning clutch..
now, i have Wagner brakes on my car.. and if you lay into the brakes HARD it smells just like burning clutch.. but i haven't smelled that since shortly after breaking in the new pads.. so i'm not sure if it was clutch or brakes i smelled.. but what could possibly make an almost new 450hp clutch slip on a nearly stock car?
Jeff2000GT is offline
post #2 of 8 Old March 24th, 2010, 02:28 PM
ryans88gt's Avatar
Do you see your rpms going up without the car accelerating? Does the clutch pedal feel funny or stick to the floor afterward and is the next gear hard to shift.
These would be symptoms of a slipping clutch.
What would cause it without very much use? Improper installation and/or breakin, oil contamination, a clutch cable setup that is putting too much preload on the pressure plate, excessive track use, poor driving habits.
ryans88gt is offline
post #3 of 8 Old March 24th, 2010, 03:15 PM Thread Starter
i did recently adjust my cable so that the clutch engages a little closer to the floor.. it started after that.. so would you recommend adjusting it back out more to a stock engagement point?
post #4 of 8 Old April 1st, 2010, 03:37 AM Thread Starter
*BUMP*
Anybody? ... Anybody?
post #5 of 8 Old April 1st, 2010, 03:48 AM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
move it back to stock and see what happens, you might have adjusted it a little to much and the TOB is putting a little pressure on the driaphram fingers and causing the clutch to slip. no harm in adjusting it back to see what it does
Teksid short block, Ported 2v heads, Custom ground cams, Edelbrock Vic Jr intake, Brandon Alsept tuned
F8L GT is offline
post #6 of 8 Old April 1st, 2010, 04:30 AM
[QUOTE=ryans88gt;2734572]Do you see your rpms going up without the car accelerating? Does the clutch pedal feel funny or stick to the floor afterward and is the next gear hard to shift.
These would be symptoms of a slipping clutch.QUOTE]
also if it "shakes" the car (like a Fu**** motor mount.) when you go to engage it in either 1st or reverse (esp. slowly) you can almost hear a harmonics sound..
happened to my friends '00 v6. and what it was, was his flywheel needed to be resurfaced.
try that cable adjustment first tho.. might just be that you put it alittle to close to the floor.
MM COBRA MEMBER #75
Spoolin's For sale $h!*
http://www.moddedmustangs.com/forums...es-galore.html
spoolin_84svo is offline
post #7 of 8 Old April 1st, 2010, 06:08 AM Thread Starter
I shall try this.. another tidbit of info, shortly after adjusting the clutch the last time, i began to notice a very faint 'squeak' between gears.. but the strange part was that squeak happens in the instant of time between when i let off the throttle and just before i begin to hit the clutch.. but not WHILE i'm pressing the clutch, it's really strange.. well i shall try the cable adjustment I'll just go back to stock engagement point to be safe.. hrmpph..
post #8 of 8 Old May 3rd, 2010, 01:22 PM
mine makes the same noise when i let off the gas i think it might be the flywheel but im not sure???? let me know if u find out
kkent is offline
Human Verification
You may not post new threads
You may not post replies
