wanting to build a 351 and need some help with advice and ideas
Old March 26th, 2010, 02:10 PM   #1
mgrah87 is on a distinguished road
i found a 78 351w and need to know if its a good block to work with or not? i plan on it being a carbureted motor also have been looking into sbf pro comp alluminum heads, running a stock crank and stock sized pistons and want to spray. any ideas on cam sizes or what type pistons to run or valve train and rockers would be much appreciated!
Old March 26th, 2010, 03:44 PM   #2
2001 Mustang GT
N/A
Huxley is on a distinguished road
Send a message via AIM to Huxley Send a message via MSN to Huxley
You want a 351c motor. The valves on a 351w are inline versus the canted valves on a 351c. Better flow basically.
Old March 26th, 2010, 04:12 PM   #3
couldnt i just put a diff head on the 351w? also what about the year of the blocks? any clues on what years to stay away from??
Old March 26th, 2010, 04:23 PM   #4
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
I have a 351 roller block in storage just in case I get another fox body. I plan on doing a forged 408 stroker setup with an agressive cam, Victor heads and a Victor intake. This should net somewhere in the 500-600 hp range without spray.
If i get another fox body that is...........
Or maybe an older classic like a 1st generation fastback or a 69/70fastback.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old March 26th, 2010, 05:35 PM   #5
sounds pretty nasty! im just confused and getting so much diff advice on what to do. i want to start with a 351 and go with a procomp sbf head. the block i found is a 78... is that anygood??
Old March 30th, 2010, 04:26 PM   #6
just-agt's Avatar
2001 MUSTANG GT
just-agt is on a distinguished road
from what i have been told the 69 blocks are the toughest but you should be fine with the 78. We run a late 70s 351 block in our modified street fox body. it has an all forged 414ci bottom end with a main girdle with AFR 225 heads solid roller cam and 225hp shot of nitrous and we havnt had any problems with the block. how much are you gana be spending on the procomp heads?
Threads Similar to: wanting to build a 351 and need some help with advice and ideas
351 build Hunt_chevs 5.0 Mustangs 11 January 20th, 2010 08:51 PM
Steering Issue in my 351 build MustangMatt96GT 5.0 Mustangs 12 April 26th, 2009 10:22 PM
Some advice on building a 351 black88 5.0 Mustangs 9 July 7th, 2008 01:40 PM
Advice/Ideas NMR-2vGT 96-98 25 February 20th, 2008 09:48 AM
bout to do a 351 swap any advice kratos2250 5.0 Mustangs 13 June 21st, 2007 01:14 AM
