FRPP hot rod cams
Old March 26th, 2010, 07:03 PM   #1
2010_LS1H8R's Avatar
2011 Mustang GT w/Brembo
13.30@109
2010_LS1H8R is on a distinguished road
FRPP hot rod cams
Will the FRPP hot rod cams void the vehicles warranty?
2011 Grabber Blue Mustang GT
Best ET 12.38 @ 111mph 4000ft above sea level
http://www.youtube.com/watch?v=Z-54c...f6AUAAAAAAABAA
Old March 26th, 2010, 11:14 PM   #2
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
Thumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the rough
I hope not, those would make your car sound so sick...
2001 Cobra with SRA swap, modded for twisties
MM Cobra Club Member #76
Old March 27th, 2010, 12:39 AM   #3
mpboy's Avatar
2002 GT
99.99@999.9
mpboy has a spectacular aura aboutmpboy has a spectacular aura aboutmpboy has a spectacular aura about
"In essence, the presence of an aftermarket part by itself does not "automatically void" your entire vehicle warranty. However, should the improper installation or function of an aftermarket part cause an O.E. part or related system to malfunction or fail, what will likely happen is that the Dealer will refuse to perform a warranty repair or replacement of that part or system. They are entirely within their rights to do so because unjustified component replacements (read: no defect in workmanship or material as per O.E. operating specs) means stiff warranty audit repayments or even warranty fraud charges. Dealers are not authorized to void a warranty (only VWGoA can do so, in writing), although many wrongly interpret refusal to repair under warranty to mean that the warranty is void.
Be careful in interpreting the warranty booklet texts properly. Keep in mind that the manufacturer is obligated to warrant the workmanship, materials and vehicle system functions as per their original design/build specifications, test protocols and US certification compliance, and that the entire vehicle is made up of many interdependent systems. For example: excessive lowering of the vehicle or installing stiffer springs alters the rates at which vehicle weight is transferred during panic braking. Should these rates exceed those calibrated in to the various sensors that provide longitudinal and lateral acceleration data to the Airbag system (and other systems that share such data on the vehicle CAN-Bus), proper airbag deployment could be compromised.
Caveat Emptor. If you want to play, be prepared to pay"
Originally Posted by Dennis View Post
i fail to see the humor here. the farve thing ok its funny. but that shit there is just fucked up.
Wow Chris. You are the square root of stupid.
Eh, I personally think 4" is too big.
Old March 27th, 2010, 01:50 AM   #4
13.30@109
so i should see if i can get them installed @ the dealer then. after all it is a ford part.
Threads Similar to: FRPP hot rod cams
FRPP hot rod cams?? 20gt08 2005 - 2010 50 November 18th, 2009 10:39 AM
FRPP hot rod cams?? 20gt08 5.0 Mustangs 3 November 11th, 2009 05:15 PM
FRPP Hot Rod Cams BLACKBULLITT'09 2005 - 2010 48 February 28th, 2009 01:12 AM
FRPP Hot Rod Cams 07GTconvertible 2005 - 2010 67 January 25th, 2009 12:20 AM
FRPP Hot rod cams 05roush0090 2005 - 2010 15 March 24th, 2008 01:27 PM
