Electronic issues
Old March 12th, 2007, 01:46 PM   #1
putermech's Avatar
1999 GT Black Coupe
putermech is on a distinguished road
Electronic issues
99 GT 63550 miles as of this post
Having issues with odometer turning off, along with a beeping sound when the lights are on and sometimes the wipers turn on. On some days, everything is normal. Of the three listed, done happen all together at the same time...it's one or the other. I thought maybe the turn signal arm but that doesn't explain the odometer turning off. Possible bad cpu chip or grounding of some sort?
Thanks.
Old March 12th, 2007, 02:24 PM   #2
dmachine22's Avatar
1998 Z28
dmachine22 is on a distinguished road
Re: Electronic issues
Thanks.
yeah I have 99GT also and had that problem I took out my guage cluster and found there were some loose wires so I put the wires back in and used some strong tape and never had a problem since, but sounds like a loose wire to me!
Unknown
Old March 12th, 2007, 02:37 PM   #3
putermech's Avatar
1999 GT Black Coupe
Not looking forward to removing the cluster...but that would save me a trip to the mechanic only to find out it's a wire unplugged. Thank bro
5 Speed w/ Trac-control
Old March 12th, 2007, 02:46 PM   #4
putermech's Avatar
1999 GT Black Coupe
BTW last 5 on the vin are 33243
Is your near that?
Thinking maybe the last few in production may have the same issue.
Old March 12th, 2007, 04:17 PM   #5
dmachine22's Avatar
1998 Z28
Is your near that?
the cluster is rather easy to remove I know it looks like a lot but all it is is bolts and as for my vin I'm not to sure my car is at the shop getting a tune up but ill let you know when I get it back!
Unknown
Old March 12th, 2007, 09:40 PM   #6
putermech's Avatar
1999 GT Black Coupe
I pulled the cluster and found nothing wrong. Little dust but all wires are strongly connected to the two plugs. It was easy to pull...I may add blue leads now...=)
Old March 12th, 2007, 11:09 PM   #7
dmachine22's Avatar
1998 Z28
Wow well I couldn't tell ya then cuz I had those exact problems but maybe yours stems from a grounding wire as you said earlier or maybe something is touching that shouldn't!
Unknown
Threads Similar to: Electronic issues
where can i find a electronic flasher unit 4 a 98gt iluvmycar 96-98 3 July 27th, 2007 11:58 PM
ECTED, electronic locking re-end review. czwalga00gt 99-04 2 June 25th, 2007 10:19 PM
Electronic Problems??kinda sorta? Bies08 V6 Mustangs 44 May 7th, 2007 10:49 PM
Baumannator TCS electronic Transmission Control System loudenough Parts 0 November 18th, 2006 12:33 PM
Installing An Electronic Boost Controller MikeyS281 Audio/Video 4 September 19th, 2006 04:49 PM
