Rear driver side sagging
I have 2004 Mustang and I had H&R super sport lowering springs and all new poly Isolators installed buy a local mustang shop and when I got home I noticed that the driver side rear is about 1/2inch lower then the pass side rear and the pass side front is just alittle bit lower then the drive side front. Thats on level ground too. I talked to the shop who installed them and they said wait 2weeks to see if they will settle. Its been over a week and its still the same. Has this happened to anyone else and if so what could be done to fix this? Thanks!
![]() ![]() ![]() ![]() ![]() iTrader: 13 reviews
I have the exact same problem only mind is a 1/4in off and I have not measured the difference on the front of the car only the rear.
Stance Issue Click^^
Thanks for the info! I looked at my rear springs today and the pigtails were both facing different ways, one was facing the back and the others facing the front. Would it make a differance if both were facing the same way? Thanks
2001 Cobra
14.2@102 (I suck)
happened to me after i did my springs. wait 400 miles then look. springs settle a little bit. I put the rear right spring on one day, let it sit overnight with the wieght of teh car on it, then did the other the next day. The one a did first sat like an inch lower for a while.
![]() 2001 Cobra with SRA swap, modded for twisties ![]() MM Cobra Club Member #76 |
Threads Similar to: Rear driver side sagging
| Driver side fender help | Bushy | 5.0 Mustangs | 8 | February 16th, 2010 02:59 PM |
| rear window trim sagging? | turbot4 | 99-04 | 38 | April 8th, 2009 09:16 AM |
| car sagging rear driver side | 91cobra5.0 | 5.0 Mustangs | 6 | December 13th, 2008 12:41 PM |
| driver side door | stangstrip | 99-04 | 11 | July 30th, 2008 04:13 PM |
