Ride Height Issues
Old June 3rd, 2010, 08:21 PM   #1
1996 Mustang 3.8l
Walters97Racing is on a distinguished road
Ride Height Issues
I have a 96 mustang that sits extreamly high in the back. i have nitto nt555 245/45r17's on the front and nitto nt05 315/35r17's on the rear. the front of my car sits about 3 inches off of my tire. the rear of my car on the other hand sits over 6 inches off of the tires. is this normal for a stock suspension? I was thinking about lowering it around 1.5inches to 2 inches to hope to bring it down.
Thanks, TWR
96 v6 - needs v8
03 Roush - needs turbo
06 F250 6.0 - needs stepladder
Old June 3rd, 2010, 10:03 PM   #2
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
Thumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the rough
stock suspension does like to wheelgap it up. idk about 6 inches but I remember it being pretty high. Lowering springs will solve your problem.
2001 Cobra with SRA swap, modded for twisties
MM Cobra Club Member #76
Old June 4th, 2010, 01:19 AM   #3
99 mustang GT
ForestGRN_Ghost will become famous soon enough
Send a message via MSN to ForestGRN_Ghost
sounds about right for stock.
looks like a small sized truck.
lowering springs can be found for pretty cheep though
Old June 4th, 2010, 01:26 AM   #4
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
Post up some pics and we will be able to tell you if its normal for stock
Old June 4th, 2010, 09:23 PM   #5
1996 Mustang 3.8l
96 v6 - needs v8
Old June 4th, 2010, 11:08 PM   #6
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
that looks about normal for stock springs
Old June 5th, 2010, 10:49 AM   #7
1996 Mustang 3.8l
Does anyone happen to know the lowest spring package i can get for this car? id like to get it as low as possible or atleast as low as our other mustang ...
96 v6 - needs v8
Old June 5th, 2010, 11:46 AM   #8
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
that other mustang isnt that low because of the side exhaust. But if you went with eibach sportline springs, i think you will achieve what you are looking for
Old June 5th, 2010, 12:07 PM   #9
1996 Mustang 3.8l
the other mustang is accually a roush. made by roush. the company we bought it from never gave us the side emblems for it, though it is a certified roush mustang stage 2. i was looking at the H&Rspring kit from A.M. because they lower the car 1.75 (rear) and 1.6 (front). how much lower could i go and where could i get that low of a kit?
96 v6 - needs v8
Old June 5th, 2010, 12:15 PM   #10
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
the sportline kit is lower than the H&R kit and you can get them from here
79-04 Mustang Eibach Sportline Lowering Spring Kit at LRS - Same Day Shipping!
Old June 5th, 2010, 12:22 PM   #11
1996 Mustang 3.8l
my mustang is only a v6.. i was going to put the 4.6 v8 in the car but after realizing all of the work to be done for that i decided id just leave my 3.8 in it, stroke it, all the extras, and throw a turbo on it. but right now shes just stock. how will these prings make her handle?
96 v6 - needs v8
Old June 5th, 2010, 05:07 PM   #12
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
the sportlines are good. if you want lower and even better handling go with coilovers
Old June 5th, 2010, 08:35 PM   #13
cale2006's Avatar
2006 Mustang GT
cale2006 has a spectacular aura aboutcale2006 has a spectacular aura aboutcale2006 has a spectacular aura about
sportlines are good but you have to take in consideration getting other upgrades with such a aggresive drop.
Originally Posted by 07 Boss View Post
Why not? I think getting stroked and blown is the way to go. Those are my plans.
MM Military Crew
SSgt USAF / DIA, NGA
gamer tag carjax06
Old June 5th, 2010, 08:39 PM   #14
silver03gt's Avatar
2003 Mustang GT
14.16 @99.03
silver03gt is on a distinguished road
With the sportlines you will need to get cc plates and new shocks and struts (if you still have stock shocks/struts).
Military Crew - United States Navy - Second Class Petty Officer
My 2v build - MMR 1000 rotating assembly, Stage 3 heads/cams, 76mm turbo. Shooting for 700+rwhp.
Old June 5th, 2010, 09:01 PM   #15
cale2006's Avatar
2006 Mustang GT
well you can ride one stock ones still, it's just bound to fail sometime.
MM Military Crew
gamer tag carjax06
Old June 5th, 2010, 09:03 PM   #16
cale2006's Avatar
2006 Mustang GT
if you don't end up doing all of the above upgrades ith the sportlines then your going to get new front tires real quick.
MM Military Crew
gamer tag carjax06
Old June 5th, 2010, 11:01 PM   #17
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
i never got cc plates....
it altered the caster by like 2 degrees and gave me about .7 degrees more negative camber when adjusted as far as possible. the alignment guy said it should be fine.
Old June 5th, 2010, 11:32 PM   #18
cale2006's Avatar
2006 Mustang GT
.7 isn't to bad but watch your inner wear
MM Military Crew
gamer tag carjax06
Old June 5th, 2010, 11:34 PM   #19
1996 Mustang 3.8l
thats what im hoping. ive got an alignment machine avalible that i can personally use so ill be making the adjustments myself. ill know for sure if it is absolutly needed. what shocks and struts should i get with such an aggresive drop?
96 v6 - needs v8
Old June 5th, 2010, 11:51 PM   #20
1996 Mustang 3.8l
also, is bumpsteer kit needed with a 2 inch drop?
96 v6 - needs v8
Threads Similar to: Ride Height Issues
Ride Height Issues Walters97Racing 96-98 4 June 4th, 2010 02:46 AM
Ride height 1968coupe Classic Mustangs 2 July 27th, 2009 11:03 PM
89 5.0 rear ride height gotime89 5.0 Mustangs 7 February 12th, 2009 02:28 AM
ride height graystang01 The Clubhouse 18 January 17th, 2009 02:52 PM
Looking for ride Height Hawaiianbro 99-04 30 February 14th, 2008 05:23 PM
