Need help with the 3.55 Gear Ratio
Old March 30th, 2007, 09:00 PM   #1
Lil_M's Avatar
Lil_M is on a distinguished road
Hi
I just installed a 3.55 gear ratio in my 97 mustang GT
And it does a noise when I release acceleration
So..
Can you help me with this??
Old March 30th, 2007, 09:05 PM   #2
2007calispecial is on a distinguished road
you didn't do the job correctly, take it to a place.. why 3.55?? AT LEAST 3.73!
Old March 30th, 2007, 09:46 PM   #3
ujslost's Avatar
tighten the pinion nut up a little bit like a 1/4 a turn and drive it again,
you just have the lash set to loose, if it whines when you let out of the throttle
Old March 30th, 2007, 10:07 PM   #4
quickblu is on a distinguished road
+1 pinion nut needs tightened
98 bright atlantic blue Cobra
mods:
Bassani headers & offroad Xpipe
steeda triax & 4:10 rear end gears
1 3/4" lowering kit with control arms
built 03 COBRA motor with comp cams 01 intake and vortec supercharger & intercooler
Old March 31st, 2007, 01:47 AM   #5
Lil_M's Avatar
Thanks guys
I am going to try it now
Old March 31st, 2007, 11:22 AM   #6
ujslost's Avatar
if it still whines, when you let off the gas then tighten it up a smug more!
if it roars all the time or when your in the throttle its to tight
Threads Similar to: Need help with the 3.55 Gear Ratio
4:10 gear ratio sugarfree V6 Mustangs 81 September 24th, 2007 11:41 AM
Gear ratio 1BADSTANG 5.0 Mustangs 13 September 17th, 2007 11:27 PM
What gear ratio should I use? Jackson 5.0 Mustangs 9 March 23rd, 2007 12:35 AM
Gear Ratio Exseque 2005 - 2010 10 March 9th, 2007 02:27 AM
Gear Ratio Finder 00SoSlow V6 Mustangs 4 March 11th, 2006 02:37 AM
