2003 Mustang GT
Tr 3650
My 3650 in my 03 gt is acting up if I take the engine over 3k I can't hardly put it into the next gear any ideas of what the problem might be!
syncros.
Vortech V2 SI, 400RWHP 389RWTQ |
!FACEPLATED!
only one gear or all of them? if theres no grinding and on all the gears it sounds like a clutch issue
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
11 Mustang GT
Track times coming soon.
i agree with fl8.
2011 Mustang GT MT. Ford Racing K springs, Boss intake manifold, JLT Cold air intake, BBR O/R Xpipe, Ford Racing 4.10 gears, TA Rear End Girdle, VMP E85 Tune/BBR 93 Tune. |
2003 Mustang GT
There's no grinding just hard to get into gear just had a ram hdx installed less than 2000 miles ago. Also when I'm idling there is a chattering sound coming from the transmission area and when I push the clutch in it stops making noise.
11 Mustang GT
the input shaft bearing mingt be bad that could be the noise in neutral. and you could have a bent shift fork and that will make it hard to get it into gear.. F8L knows alot more about transmissions than me.. maybe he can come up with another idea.
2003 Mustang GT
Thanks appreciate the input.
!FACEPLATED!
you just had a new clutch put in. do you have anything else aftermarket? like quadrant, of cable or firewall adjuster?
2003 Mustang GT
That's all stock just the clutch is upgraded
!FACEPLATED!
try adjusting your clutch quadrant. I will see if I can find the steps on how to do it
!FACEPLATED!
2003 Mustang GT
Thanks I will try it and see what happens
2003 Mustang GT
The hard shifting is also intermittent and the adjusting work for a couple of minutes but went right back to doing it should I replace the cable and adjuster and quadrant.
Threads Similar to: Tr 3650
| my 3650 took a SH!T | Willy Mo | 99-04 | 15 | April 8th, 2010 10:25 PM |
| how much hp tr 3650 | competition orange | 99-04 | 11 | April 1st, 2010 11:23 PM |
| Tr-3650 | Untamed3708 | 99-04 | 1 | March 7th, 2010 06:51 PM |
| from t-45 to t-3650 | vicstric | Modular Mustangs | 1 | February 18th, 2010 09:40 PM |
| tr-3650 | emgjsdk1 | 99-04 | 18 | May 10th, 2008 08:23 PM |
