2001 Mustang GT
4.6 3v swap into a 2001 GT
First of all i would like to say hello to everyone, I'm new here but not new to mustangs. To cut to the chase i'm looking to swap a 4.6 3v into my 2v stang. I've been able to find lots of useful info but there are some questions I still have. Just to give everybody an idea of what I'm trying to do here is my situation:
A: My timing chain guides got shredded and caused my timing chain to skip a sprocket or two and sent a valve into my piston and locked my motor at 70k no less. Tried turning by hand and was afraid I might snap the crank bolt. So basically I have a boat anchor on my hands. B: I'm planning on swapping a 3V motor, figured I'd get the 3V since my motor is probably in need of a teardown and 3V's are pretty cheap. C:I'm planning on using the Logan Motorsports conversion kit, Modular Head Shop Stage 2 cams, FRPP Intake, BBK Twin 65mm TB, Pacesetter LT and X-pipe (I know not the best but keeps me in my budget), and some type of CAI (not sure what one will work yet), tuner, Steeda Tri-Ax Shifter, 3.73 gears and a Cobra R hood. My car already has a SLP loudmouth exhaust, Eibach springs, f/r sway bars, CAI and Steeda clutch quadrant with the adjuster. The main question that I have is will a 07+ Explorer 4.6 3V work in my car, are the motor mounts different like the aluminum 4.6 or are they the same as the older 2V cast iron. Will the adapter plates that MMR & SHM make to put the older blocks in the S197 work to put a newer block in a SN-95 chassis? Are the 3V heads the same on the Explorer as the Mustang? Are the fuel lines the same, I believe they would be as they are both modulars but I'm just guessing? Are the timing cover's similar or can a Mustang one be used? Is there anything I might be missing or something different I should do that anyone knows of. Thanks for any help you guys might have ![]() P.S. Please no comments saying I should go with a 4V..... Just not what I'm looking to do right now... unless you know of a good one for under $2000
Last edited by Hellsperm; September 24th, 2010 at 12:24 AM. Reason: wrong year of vehicle |
I would suggest pm'ing "mustang_gtr_99". He dropped a 3v in his 99 a while back. If he's still floating around he'll know everything you need to know.
New Private Message to mustang_gtr_99
2003 Mustang GT-SOLD-1996 SVT Cobra -SOLD-
12.35@114.08 w/ 1.88 60'
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 7 reviews
You can get a 4v out of a Mach or 99/01 Cobra for that money, and it will be a lot easier to install than the 3v. I put in an '03 cobra engine and it was pretty easy. That costs more than what you're looking at but it's also, forged, best 4v heads, blower, and all the blower accessories. You can definitely do a 4v swap for cheap.
Do the Right Thing, Cook. ~Zip. |
hi crossfire,...nice link shared,..it contain very useful information for many others who need this,..
Montclair Personal training gym |
Threads Similar to: 4.6 3v swap into a 2001 GT
| 2002 GT VERT / 2003/04 MACH 1 Engine Swap | JBasco20 | Modular Mustangs | 5 | February 10th, 2011 10:23 PM |
| 2002 motor swap into my 1996 GT | Blake96GT | 96-98 | 9 | August 18th, 2010 04:51 PM |
| 2002 GT Engine Seized- Swap Options | nacree | 99-04 | 28 | June 16th, 2010 09:19 PM |
| 2002 4.6L swap into 98 V6 | MyCarPwns84 | 99-04 | 9 | June 15th, 2010 01:37 PM |
| 1997 V6 to a 2002 V8 swap | 5plus1 | V6 Mustangs | 5 | August 14th, 2009 02:48 PM |
