LinkBack (1) | Thread Tools |
#1
2001 Mustang Gt High/Hanging Idle
I just bought a 2001 Mustang gt and have noticed that the idle like to stick a little bit on it. It kinda hangs at about 2000, then 1500 then sticks at about 1200. Is this a common problem? Any idea what it could be?
pull off the iac valve (idle air control) and clean it real good with some carb and choke cleaner. get a q tip and clean all the down and around the pluger(shaft,bar,rod). reinstall and start. its a very common part/problems on all fords with a 4.6L
its located on the front of the intake plenum and has 1 plug and 1 hose that goes back to the intake |
+1 on what Bad98 said, or a really big vacuum leak?
Rollin' 18/ pushin' 2
The silver thing is the IAC.
1996 Mustang Gt
Depending on how long it sticks, possible throttle cable problem. Prolonged sticking, bad98gt most likely is correct.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/modular-mustangs/189854-2001-mustang-gt-high-hanging-idle.html
| Thread 2001 Mustang Gt High/Hanging Idle | Forums at Modded Mustangs | BoardReader | This thread | Refback | February 4th, 2012 07:57 PM | |
Threads Similar to: 2001 Mustang Gt High/Hanging Idle
| 2001 Mustang Gt High/Hanging Idle | stangballer | 99-04 | 3 | October 28th, 2010 09:43 PM |
| Need help with high hanging idle and a swarm of engine codes | romanb | 99-04 | 14 | October 2nd, 2010 08:27 PM |
| Mustang High Idle | slydwayz%) | 5.0 Mustangs | 2 | April 20th, 2010 11:01 PM |
| Idle surging and hanging on 1992 mustang | WhinninLX | 5.0 Mustangs | 2 | April 13th, 2010 02:28 PM |
| Aftermarket TB/Plenum hanging idle/low idle issues! | Novanutcase | 99-04 | 12 | August 13th, 2008 11:24 AM |
