Need advice on shifting issue
Old November 10th, 2010, 11:35 AM   #1
cobracutie3 is on a distinguished road
Hey guys
New to this site..
Just recently bought a 99 cobra 80,000 miles on it... had it for about a couple weeks, was having an issue with the shifting (wanted it to bite lower) Car has a Steeda firewall adjuster on it, adjusted/loosened it up a bit, now the car wont even shift into any gears at all unless the car is not running...
What could my problem be..?
just bought a new clutch cabe too was going to install later today but wanted to get advice from the guys beforehand
thanx
Old November 10th, 2010, 07:36 PM   #2
AnotherS197GT's Avatar
2008 Mustang GT
AnotherS197GT is a splendid one to beholdAnotherS197GT is a splendid one to beholdAnotherS197GT is a splendid one to beholdAnotherS197GT is a splendid one to beholdAnotherS197GT is a splendid one to beholdAnotherS197GT is a splendid one to beholdAnotherS197GT is a splendid one to behold
iTrader: 7 reviews
I had a clutch go out on a 99 Hyundai and that fucker refused to shift unless the car was off. Clutch might be toast.
          | COMP CAMS | FRPP | PYPES | CDC | UMI |
Old November 11th, 2010, 02:50 AM   #3
tfofkyle's Avatar
02 Mustang GT
tfofkyle will become famous soon enoughtfofkyle will become famous soon enough
maybe you loosened it up too much and now the clutch isnt fully disengaging. try tightening it back up and see if that helps. one or two clicks goes a long way on those firewall adjusters
on a side note im very jealous of your car
Old November 15th, 2010, 10:35 PM   #4
1996 Mustang Gt
hjb96gt is on a distinguished road
Agree with the guy above, definitely too loose now. Once youve gotten it tightened back up, you can slightly move the pedal itself by loosening the bolt holding it in place(mark where it was aligned with whiteout) and you have a small about of room to play with the pedal before you must tighten that bolt back. I personally havent tried this but it seems possible and its a least worth a try. If it works, tighten the clutch cable as needed. If it doesnt work, place it back in the former position(refer to marks and be sure to torque the bolt to spec) and check into a pedal adjustment kit.
Old November 16th, 2010, 10:10 PM   #5
hey thanks guys..ended up being the clutch cable..the cable was bent pretty much..all messed up.i probably had something to do with it.. oh well u live and learn.. thanks for all help.. i know where to come next time
Threads Similar to: Need advice on shifting issue
Transmission Shifting Issue Stangguy18 V6 Mustangs 4 June 30th, 2010 07:44 PM
update on my shifting issue 07 STROKER 2005 - 2010 39 October 6th, 2009 09:50 PM
shifting issue mustanginky 5.0 Mustangs 2 June 10th, 2009 06:24 PM
shifting issue psycho bob 2005 - 2010 20 May 30th, 2009 01:42 PM
urgent shifting issue gtcs mustang 13 2005 - 2010 25 February 23rd, 2008 04:02 PM
