looking to get a s281 please help
im looking to get a 97 s281: heres the add does it seam like a good deal? he only wants 9000$ ......Selling my 97 Mustang Saleen S281, it's #120 for the year 1997. Vehicle is in good condition for a 97', if anything just needs a little TLC from sitting in my driveway. The only has just over 70k miles. Engine has a lot of upgrades (all done by owner before me) and is supercharged, pushes about 400 HP to the rear wheels and 430 TQ. I had JBA titanium ceramic headers and exhaust done by JBA in San Diego (Stationed there in Military) and was dyno tuned. Put 4 new tires on probably about a year and a half ago, but maybe only put a few thousand miles on it since then.I'M BUYING A HOUSE AND CAR NEEDS TO GO!!!**
2006 Saleen S281 S/C
Sounds good. Is there a vin? Run a check. Did they post pictures up?
![]() Saleen SuperShaker,Brenspeed Tune, 3.2 Pulley, 39lb Injectors, Dual GT500 Fuel Pumps, o/r Prochamber, BMR LCA's, Steed Heat Exchanger, Steeda Belt Tensioner, Steeda Tri-Ax Shifter, Dynotech aluminum driveshaft, V10 Water Pump Pulley |
Rollin' 18/ pushin' 2
Call Saleen directly @ 1-800-888-8945 with the Bumper Number and the last 6 digits of the VIN and they can authenticate it for you.
im almost 100% its a saleen its got badges everywhere and underthe hood. but i will run the vin. only thing is the engine shakes alittle? and theres this little stem behind engine that whistles he said the caps missing? didnt seam to have a problem when driving. very smooth and powerful i think i might just grab it he said its boosting at 15psi i know too much about saleens but that sounds alittle high?
97s218 you stole my username! haha or i tried to steal yours actually my badddd*
if i get this car. is it alot more expencive than gts? like is there any parts that have to be ''saleen'' other than body things? and are superchargers costly and alot to maintain?
It probably needs new motor mounts. The supercharger is aftermarket. Saleen did not offer a supercharged S281 in 97. They did offer a supercharged S351 though.
Name thief.
Yes, the maintenance costs are higher. You should realize that as awesome as the Racecraft suspension is, it is 13-14 years old and more than likely needs to be replaced.
yes deffently needs suspention. its so confusing ive never seen a suspention setup like that? where can i buy a full set for cheaper online? like vendor ect... and is that a bad thing thats its aftermarket?
The actual setup should be the same as a gt, just with lowereing springs and better shocks and struts and a better front sway bar with poly bushings. It should have a set of 3.55 gears in the rear and a saleen body kit with saleen wheels. It should have a set of Saleen plug wires under the hood. Other than the striping and badging that was the only difference between a stock GT and a Saleen S281 back then. Anything else different on the car is aftermarket and has been changed by the owner or prevoius owners.
If you can post up some pics of the car and the suspension we can help you figure out what additional mods have been done to it.
the dude doesnt have any of that. but it puts down some pretty good numbers 392whp/429 wtq i believe
is yours s/c'd?
? and is the S/c hard to maintain
I'm working on a forged shortblock with ported svo heads, custom cams and an svo blower right now. It's not together yet.
goodshit sounds like a decent setup. but like i said are the vortec s/cs hard/xpencive to maintain?
Hooo Ha Ha
This is very confusing with you 2
![]() 410rwhp 520rwtq @ 12.9 psi |
No doubt.
haha sorry about that you cant tell i have a _ in mine cause of the line. but this stang has JBA titanium ceramic headers and exhaust done by JBA in San Diego is that worth keeping or swappin for some longtubes ( the jbas are shortys.) would it make a difference with longtubes and the blower?
1998 mustang cobra
the longtubes will make a decent difference. superchargers arent that overwhelming to maintain. i believe as long as you dont overspin them they will last over 100k miles. they do have seals in them that will need to be replaced at some point. i think the seals are less than $1g to replace.
HP twin turbo - 691hp/608tq with 15lbs huffed in (old setup) comin soon...ON3 turbo kit, PTE7175 |
Threads Similar to: looking to get a s281 please help
| S281 questions | Cypha | 99-04 | 4 | September 10th, 2010 11:59 AM |
| 06 s281 saleen | shamntgmry | 2005 - 2010 | 36 | June 6th, 2008 09:53 AM |
| S281 SC come in an auto?? | 94v6blkndred | The Clubhouse | 11 | January 29th, 2008 01:32 PM |
| S281 Saleen Help | 94stang | 99-04 | 3 | December 17th, 2007 01:54 PM |
